August 13, 2018, 11:15 |
Trimmed Mesh Cell Quality
Indiana (IN)
Rep Power: 8 |
Good Morning,
How come if you have a perfect cube and you use a trimmed mesh, you will never have all the cells at 100 % quality? Thank you! |
August 13, 2018, 19:55 |
Rep Power: 24 |
You can certainly mesh a perfect (or very, very closer to it) cube with the trimmer. But you need your cube to align perfectly with the octree mesh.
The trimmer autogenerates a background mesh over objects and then 'trims' out the cells that are not in desired volumes. If the desired volume is perfectly aligned with the background mesh, then you get nearly exactly the perfect background mesh. |
September 14, 2018, 13:10 |
Indiana (IN)
Rep Power: 8 |
Thank you, how do I perfectly align the desired volume with the background mesh then?
September 17, 2018, 11:16 |
Matt
Rep Power: 18 |
I believe that would be a structured mesh and you cannot do that with star-ccm, currently. You would have to mesh using a 3rd party software and import that.
I could be wrong. |
September 17, 2018, 12:30 |
Owen
Rep Power: 8 |
You can use "Perform Mesh Alignment" in the trimmer to accomplish what you are describing. The wrapper has this same functionality.
You can use that alignment point as an anchor for the bounding box of the geometry. Look at the documentation for more information. |
September 17, 2018, 23:28 |
#6 | ||
Rep Power: 24 |
This will allow you to align the mesh at a particular point, but IMO a superior method is to have the trimmer use a particular coordinate system. You can define a coordinate system under the trimmer mesher object in an operation or continuum. The coordinate system approach allows the background mesh to have any orientation and position. Quote:
STAR-CCM+ can make structured meshes via the Directed Mesher. The solver will still treat them as unstructured. They'll have great quality though. |
cell, quality, trimmed mesh |
[mesh manipulation] How to write cellSet for different regions in constant/polyMesh/sets | Struggle_Achieve | OpenFOAM Meshing & Mesh Conversion | 3 | June 17, 2019 09:29 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 03:21 |
[Other] Mesh quality | vitorspadetoventurin | OpenFOAM Meshing & Mesh Conversion | 0 | November 28, 2014 18:27 |
[ICEM] mesh in-dependency and mesh quality control | sujay | ANSYS Meshing & Geometry | 0 | February 20, 2013 02:06 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
