July 7, 2018, 11:51 |
Pressure drop: Pin-fin heat sink
Michael Kraus
Rep Power: 10 |
Hello everyone,
i have some issues to calculate / simulate the pressure drop over a pin-fin heat sink. Geometry description: Heat sink width: 50 mm Heat sink length: 75 mm Pin fin diameter: 1 mm Number of pins in flow direction: 10 Number of pins each row: 10 Pin fin distance (equally distributed) X-direction: 8.22 mm Pin fin distance (equally distributed) Y-direction: 5.00 mm To reduce the computation time its converted into a 2D model. In addition, only one row is simulated (--> "new width = 5 mm") See Fig. 1 for the Geometry setup Boundary conditions: - Velocity inlet: 10 m/s (for example) - Pressure outlet: 0 Pa - Two Symetry planes (red walls in Fig.1) Physics conditions: - Segregated Flow - Constant Density - All y+ Wall Treatment - Steady - Two Dimensional - k-Omega Model - Turbulent - Gas - Ref. Pressure = Initial Pressure = 0 Pa - Initial Velocity = Inlet Velocity = 10 m/s - Density and Dynamic Viscosity = constant = default values Results: Surface average report at inlet: 82.5 Pa (Fieldfunction: "Pressure") Fig2 shows the result in a scalar scene. Problem: If i compare the CFD result (82.5 Pa) with my analytical result (VDI Heat Atlas - chapter L1.4 (year 2013)) i have a huge gap. See Fig3 and Fig 4 Analytical result: 247.36 Pa Does anyone know where my mistake is? Do I forget a setting like reference pressure or pressure coefficient? Thans a lot! |
July 16, 2018, 17:26 |
Michael Kraus
Rep Power: 10 |
noone ?
July 18, 2018, 02:25 |
Rep Power: 24 |
Is 2D really a good assumption here? A pin fin will have significant 3D dynamics that you're ignoring.
July 18, 2018, 06:28 |
Michael Kraus
Rep Power: 10 |
I calculated both, 2D and 3D, versions.
Both Simulations have nearly the same results... The simulated results are still very different from the analytic ones What do i wrong? If you need more information, feel free to ask ! Thanks for your reply! My fluid is a Gas: Air |
July 18, 2018, 23:35 |
Rep Power: 24 |
I misread you're using symmetry planes before. Since this is 2D and you're only using a single line of cylinders, is that really comparable to what that book states? It has some sort of grid. Make sure that there isn't anything you're missing since you're doing a 2D analysis to compare to a correlation, which is likely developed from 3D. Are there any area values which you might be misrepresenting? I can't read the text.
I'm not really sure if symmetry planes with only a single cylinder row is a good way to run this. Having multiple cylinders will allow them to shed better if they do indeed do so. |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 00:58 |
Discrepancy between the measurements (pressure drop; VOF) | blackemperor | FLUENT | 2 | March 6, 2016 03:40 |
Mass flow rate prediction of Purge control valve using set pressure drop | enr_venkat | CFX | 11 | February 27, 2014 11:30 |
a problem in calculating pressure drop in Fluent? | yu chun | FLUENT | 1 | May 18, 2004 03:40 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
