Urgent! Boundary Conditions of Moving Reference Frame : Propeller
View Poll Results: Is STARCCM+ common to run simulation on propeller?
Not Really 3 33.33%
Yes 6 66.67%
Voters: 9. You may not vote on this poll
Like Tree1Likes
  • 1 Post By ashokac7
Old   June 22, 2018, 08:26
Exclamation Urgent! Boundary Conditions of Moving Reference Frame : Propeller
KindaHungry is on a distinguished road
Hi, I am new to CFD. I am trying to run tutorial of Moving Reference Frame: Marine Propeller in Open Water. It has mentioned that most of the boundary conditions has already defined, all I need to do is to set the velocity. If I am using my own propeller I will need to do all the settings by myself so anyone knows what is the boundary conditions that has pre-defined?
By the way, how to set the flow to be reversed? When I run on the tutorial, it shows that "Reversed flow on 28 faces on Outlet". I have no idea how to set it to be reversed flow.
Thank you very much!
KindaHungry is offline   Reply With Quote
Old   June 22, 2018, 10:51
Smile
ashokac7's Avatar
Ashok Chaudhari
ashokac7 is on a distinguished road
Send a message via Skype™ to ashokac7
For the reverse flow, We don't set this, this means that some flow is coming inside from outlet boundary. This often happens in CFD when we have some circulation or flow separation at the outlet boundary. So it may be ok to have a reverse flow.
If you are done with MRF tutorial then you may know you have to create a reference frame in tools with desired RPM, then assign this reference frame to a rotating region under motion node.
Hope this help!!
KindaHungry likes this.
ashokac7 is offline   Reply With Quote
Old   June 22, 2018, 12:01
Smile
Thanks ashokac7 ! I will try on that tutorial and I wish it that tutorial will helps! Thanks for the suggestion!!
boundary condition, propeller, starccm+
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
Setting rotating frame of referece. RPFigueiredo CFX 3 October 28, 2014 05:59
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 01:34
