June 13, 2018, 16:18 |
Delaunay Mesher cannot recover boundary.
Lucas Goulart Duarte
Rep Power: 8 |
I've encountered an error "Delaunay Mesher cannot recover boundary" while generating volume mesh on my simulation. Do you have any idea what it could mean? After the error, the symmetry plane changes and looks the image. |
July 16, 2019, 18:25 |
Pete Keys
I got the issue once when executing tetrahedral mesher. I cleared all my generated meshes and re-executed and it worked.
However, I later got the same issue and am going to try again to see if it works. Did you ever figure out what the Delaunay error means? |
August 5, 2019, 12:44 |
Miles Ratcliffe
Did you find a solution to this problem?
3D Windturbine simulation in SU2 | k.vimalakanthan | SU2 | 15 | October 12, 2023 06:53 |
My radial inflow turbine | Abo Anas | CFX | 27 | May 11, 2018 02:44 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 11:00 |
Velocity vector in impeller passage | ngoc_tran_bao | CFX | 24 | May 3, 2016 22:16 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
