May 25, 2018, 21:26 |
Generation of Vof Waves
Akshith Subramanian
Rep Power: 8 |
Hi All,
I have been trying to simulate the flow of waves over a spherical body as a project. For the numerical wave tank I have chosen a velocity inlet boundary condition for inlet, pressure outlet for the outlet and top. Bottom and far field are walls and I am using a symmetry plane. I have defined the inlet velocity and outlet pressure in terms of field functions of the waves. However I can see on the volume fraction scalar that there is a water build-up in the system. Can anyone give me any ideas on what could be going wrong? TIA Akshith |
May 29, 2018, 08:42 |
#2 | |
May 30, 2018, 19:11 |
#3 | |
Akshith Subramanian
Rep Power: 8 |
I am using a Eulerian Multiphase model. I can still see the increase in volume fraction of water. I personally feel this is a problem with the physics set-up as I did refine the mesh and make it coarse near the outlet so as to damp wave reflections into the system. Any further comments? TIA Akshith |
May 31, 2018, 20:59 |
#4 | |
HARIHARAN K
Rep Power: 11 |
June 6, 2018, 17:28 |
Akshith Subramanian
Rep Power: 8 |
Hi
Sorry for the delayed response. This is how my volume fraction scene looks like before the run and after.volume_fraction_initialization.jpg volume_fraction_after_run.jpg |
June 6, 2018, 17:31 |
Akshith Subramanian
Rep Power: 8 |
Do you have any suggestions as to what could be the problem? I have tried various meshing techniques and even used Ansys Workbench for meshing. The problem still seems to be there and it looks like something is wrong with the way I am defining my physics conditions.
June 7, 2018, 04:06 |
Hi
HARIHARAN K
Rep Power: 11 |
Hi
I believe you are using VOF model. My comments are (which come to my mind now), 1. Why the top and bottom boundaries are nearer to the sphere? Did you trying increasing them? (At least the depth). 2. If you are using first order (or fifth order wave), how many layers of cells did you keep to refine the wave height and wave length? I recommend to go for 40 layers cells per wave height and 80 layers of cells per wave length. 3. Is the sphere submerged at the starting point? I hope you set the water level in VOF Waves module correctly. 4. Are you using DFBI module to analyse the motions or the sphere is fixed? If you are using DFBI, are the initial values of rigid body properly set? 5. How did you choose you time-step? Is it 2nd order accurate? I recommend to choose 1/200th of your wave period. Hope this helps. |
June 15, 2018, 05:07 |
Raquel
Rep Power: 8 |
Have you tried to change the boundary conditions? I mean, It is usually to use the velocity inlet conditions in de inlet but also in the laterals of the tank and in the top side. Then use the wall condition in the botton and pressure outlet for the outlet. |
November 28, 2018, 10:36 |
#9 | |
Hamed
WAVES GENERATION IN A PORT OR BRAKE WAVES. important | tecnicaf1 | STAR-CCM+ | 1 | May 27, 2011 07:32 |
VOF waves breaking in my simulation | mbn1454 | STAR-CCM+ | 4 | December 12, 2010 04:27 |
Following waves generation | Nico | Main CFD Forum | 0 | October 4, 2006 08:28 |
WAVES with VOF | Panayotis Prinos | FLUENT | 1 | December 17, 2000 17:58 |
Propagation of Waves with VOF | Panayotis Prinos | FLUENT | 0 | December 7, 2000 06:10 |
