Rep Power: 9 ![]() |
So I am trying to plot the variation of Heat Transfer Co-efficient with the component temperature at a point.
I have created a point and added it to a report and created a monitor and plot from it. But I need the parameter if temperature on the axis. By default, I can select either the time or iteration on the x-axis. How do I create a plot with temperature on the x-axis and HTC on y-axis? Please Help! |
Matt
Rep Power: 18 ![]() |
First, this is an unsteady analysis correct? If this is steady-state then you will get one temperature and one HTC value at the one point you created. That isn't going to give you a curve or trendline. Assuming this is unsteady, create a monitor for temperature and HTC at that point then create an XY-Plot using those monitors. Refer to the user guide:
User Guide > Analyzing > Plotting Results > Working with XY Plots |
plot, temperature |
[openSmoke] libOpenSMOKE | Tobi | OpenFOAM Community Contributions | 562 | January 25, 2023 09:21 |
Shadow Wall and temperature | norger | FLUENT | 10 | September 28, 2019 11:43 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Inlet won't apply UDF and has temperature at 0K! | tccruise | Fluent UDF and Scheme Programming | 2 | September 14, 2012 06:08 |
monitoring point of total temperature | rogbrito | FLUENT | 0 | June 21, 2009 17:31 |
