User defined heat source
Like Tree2Likes
  • 2 Post By bluebase
Old   April 5, 2018, 16:49
Default User defined heat source
RJC
redwanamit034 is on a distinguished road
I have never used Star CCM+ before, and to be honest, have very little knowledge about its capabilities. However, I had used Fluent to model CFD and heat transfer problems. Because of license issues, we are no longer using Fluent and now I have to find an alternative. So, I am trying to assess Star CCM+ capabilities for our modeling purposes.
Is it possible to add user defined heat sources in Star CCM+ models?
Which programming language is needed to write user defined sorces/functions in Star CCM+ ?
Thanks.
redwanamit034 is offline   Reply With Quote
Old   April 6, 2018, 04:42
Sebastian Engel
bluebase will become famous soon enough
Yes. It can be defined for seperate volumes and surfaces. With some jump functions it can also be set for certain geometric locations.
It depends on your function. In most cases, you will not need any specific programming language. There are socalled user field functions, which can be created interactively within StarCCM. I hardly ever needed something else.
If you have something really complex, you can programm a small library in any prefered language plus an interface/header in java.
In general, java neccessary for writing macros(scripts) for automization and batch jobs for StarCCM. So it might be useful to stick to that.
Both ways are described well enough in the manual and the steve portal.
Best regards,
Sebastian
linyanx and ashokac7 like this.
bluebase is offline   Reply With Quote
Old   April 6, 2018, 11:00
RJC
Thanks a lot for such a good reply. I really appreciate that.
heat sources, user defined function
User defined function for moving heat source ARJUN A ASOK FLUENT 2 February 3, 2017 01:55
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 11:57
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
