Geometry feature optimization
Like Tree1Likes
  • 1 Post By cwl
Old   April 2, 2018, 06:51
Default Geometry feature optimization
António Soares
Outbound is on a distinguished road
Greetings,
Me and a colleague are wondering whether it's possible to perform geometry feature optimization in STAR.
Now, we're not looking to simply perform a shape optimization as per the " Adjoint Flow: Wing Shape Optimization" tutorial, more like moving around a feature, like say a surface hole around an area in the CAD model to try and obtain an optimal placement for particular flow feature.
Best regards.
Outbound is offline   Reply With Quote
Old   April 2, 2018, 23:28
me3840 is on a distinguished road
Yes, this is quite easy to do in STAR-CCM+.
Just parameterize your CAD model in 3D-CAD so you can change the hole location. Then you can use Optimate or Simcenter to run tons of cases to get you the tradeoffs.
me3840 is offline   Reply With Quote
Old   April 3, 2018, 11:14
António Soares
Yes, but what happens if what you're working with is a received volume Mesh geometry in .stl or.x_t format and basically all you have are surfaces, lines and edges with no defined parametric features?
Is it possible to defined these features from an existing surface mesh, even if using external tools?
Best regards,
Old   January 21, 2020, 06:14
Nadine Lock
NadineLock is on a distinguished road
@Outbound: Did you find a solution for that?
NadineLock is offline   Reply With Quote
Old   January 21, 2020, 08:53
cwl
Chaotic Water
cwl is on a distinguished road
That is not possible in Star, but you could use the feature recognition in other software and transfer CAD directly to Star with all the parametric dimensions; SolidWorks for example can do that - but it does not have a LiveLink to Star any more. NX or Inventor might help.
NadineLock likes this.
cwl is offline   Reply With Quote
[ANSYS Meshing] Symmetry feature in ANSYS Meshing RobBanks ANSYS Meshing & Geometry 0 February 22, 2017 12:03
Fill CAD Geometry voldemort Autodesk Simulation CFD 0 July 12, 2016 02:47
Import Deformed Geometry into Fluent lgamble FLUENT 1 February 25, 2016 14:59
solid-solid conduction with geometry optimization. Pablo86 FLUENT 3 January 6, 2016 21:26
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 20:42
