Star-CCM+ Macro - Loop over just wall boundary conditions
Like Tree1Likes
  • 1 Post By me3840
Old   February 16, 2018, 10:31
Default Star-CCM+ Macro - Loop over just wall boundary conditions
NH
jbatchel is on a distinguished road
I'm trying to loop over just the wall boundaries in my macro. I know I can use a Collection and getObjectsOf(ForceReport.class) to loop over just the force reports. But I think I'm missing something simple when it comes to automating this loop over getObjectsOf(WallBoundary.class).
I am not a Java programmer, so forgive me if this is a simple question. I boiled down the part I'm struggling with to the code below. As you can see I have it creating a collection of force reports then looping over those and just printing the name of the reports. It fails when trying to create the collection of wall boundaries.
I'm running on:
Red Hat Enterprise Linux Server release 6.8
And installed java version:
java version "1.6.0_41"
OpenJDK Runtime Environment (IcedTea6 1.13.13) (rhel-1.13.13.1.el6_8-x86_64)
OpenJDK 64-Bit Server VM (build 23.41-b41, mixed mode)
package macro;
import java.util.*;
import java.lang.Math;
import star.common.*;
import star.base.neo.*;
import star.base.report.*;
import star.turbulence.*;
import star.flow.*;
import star.vis.*;
import star.meshing.*;
public class testing extends StarMacro {
  public void execute() {
	// get model variables
    Simulation simulation_1 = getActiveSimulation();
	// get collection of report names
    Collection<ForceReport> forceReports = simulation_1.getReportManager().getObjectsOf(ForceReport.class);
    // loop through all the reports and give feedback
    for (ForceReport thisReport : forceReports) {
       simulation_1.println("Found Report:  " + thisReport.getPresentationName());
    Region region_0 = simulation_1.getRegionManager().getRegion("Region 1");
	Collection<WallBoundary> mybounds = region_0.getBoundaryManager().getObjectsOf(WallBoundary.class);
	// loop through all the walls and give feedback
	for (WallBoundary thisBoundary : mybounds) {
		simulation_1.println("Found Wall:  " + thisBoundary.getPresentationName());
Here's the error I get:
Playing macro testing.java
error: testing.java:30: error: method getObjectsOf in class star.base.neo.ClientServerObjectManager<T> cannot be applied to given types;
  required: java.lang.Class<X>
  found: java.lang.Class<star.common.WallBoundary>
  reason: inference variable X has incompatible bounds
    equality constraints: star.common.WallBoundary
    upper bounds: star.common.Boundary
Thank you for any help!!
Jason
jbatchel is offline   Reply With Quote
Old   February 19, 2018, 02:44
taillanm is on a distinguished road
I got around this by creating an "if condition" :
String compare = "Wall";
Collection<Boundary> MyBoundaries = region_0.getBoundaryManager().getBoundaries();
List<Boundary> MyFilteredBoundaries = new ArrayList();
for (Boundary WallTypeBoundaries : MyBoundaries) {
if (WallTypeBoundaries.getBoundaryType().toString().c ontains(compare)) {
MyFilteredBoundaries.add(WallTypeBoundaries);
and then go on with your Macro, extracting / looping over MyFilteredBoundaries.
taillanm is offline   Reply With Quote
Old   February 19, 2018, 06:09
tisa is on a distinguished road
First, I highly recommend to use an IDE like Netbeans. Makes it easier.
I don't know a way for not using an if condition, but you can use another way for your comparison, without using a String:
for (Boundary currentBoundary: simulation_1.getRegionManager().getRegion("Region 1").getBoundaryManager().getBoundaries()) {
if (currentBoundary.getBoundaryType() == simulation_1.get(ConditionTypeManager.class).get(W allBoundary.class)) {
simulation_1.println("Found Wall: " + currentBoundary.getPresentationName());
tisa is offline   Reply With Quote
Old   February 20, 2018, 23:02
me3840 is on a distinguished road
You can trade the line:
for:
if (currentBoundary.getBoundaryType() instanceof WallBoundary) {
bluebase likes this.
me3840 is offline   Reply With Quote
Old   February 21, 2018, 04:00
for:
Totally forgot about that. Much better and shorter
Old   March 2, 2018, 14:42
Default Thanks!
NH
I apologize for not getting back sooner. All of these options work, so just wanted to thank everyone for the help! I've added this to my little macro library for future use.
Thanks again,
Jason
java, macro, starccm+
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
