Modelling Quenching In StarCCM+
Like Tree1Likes
  • 1 Post By ashokac7
Old   February 8, 2018, 04:29
Post Modelling Quenching In StarCCM+
patilsachin is on a distinguished road
I am trying to model quenching of a steel ball in water. I am having trouble with the physics models to be selected.
Should I go for only CHT or also include boiling it?
If I have to include boiling, should I go for VOF, Wall Boiling, OR Eulerian Mutliphase Mixture?
Any leads in these would be highly appreciated
patilsachin is offline   Reply With Quote
Old   February 8, 2018, 04:50
Smile
ashokac7's Avatar
Ashok Chaudhari
ashokac7 is on a distinguished road
Send a message via Skype™ to ashokac7
Originally Posted by patilsachin View Post
This depends on objective of your project. But to say I will not directly go with boiling modelling. First try validation with CHT only. Hope this helps.
lcarasik likes this.
ashokac7 is offline   Reply With Quote
Old   February 25, 2018, 07:54
Well I am trying to generate a cooling curve.
Without boiling model, the temperature drop is very low.
In water quenching, the temperature drops to quenchant temperature within a 10 - 15 seconds which is not simulated if I select only CHT model.
Are there any tutorials available on Quenching?
Old   February 26, 2018, 01:44
Smile
ashokac7's Avatar
Ashok Chaudhari
Drop me your personal mail in private message. I have something to share with you about quenching. But it is from Star-CCM guide.
Old   April 10, 2018, 00:26
sthish
sathishkrazy is on a distinguished road
Yeah you need to activate vof Boiling model and use transition boiling in order to obtain cooling curve
Follow the below approach for quenching simulation.
This needs to be done in Transient
Keep the top portion of rectangular Box(which u are filling with water) as pressure outlet..ie open to atmosphere.
Define Two phases ie water and Vapour, primary as water& secondary as vapour.
Model Steel ball as solid and define properties and specify temperature under initial conditions(as this is transient simulation)
sathishkrazy is offline   Reply With Quote
boiling, physics models, quenching
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
CFD in Naval Hydrodynamics, Off-Shore and Wave Modelling with OpenFOAM hjasak OpenFOAM Announcements from Other Sources 2 February 13, 2017 05:59
error message cuteapathy CFX 14 March 20, 2012 07:45
Advice on multi-phase flow modelling Martin Main CFD Forum 3 October 14, 2008 06:16
Computational Modelling of Vortex Separators May Lim Main CFD Forum 6 November 13, 1998 13:36
