Floating Point Segregated Flow Solver Error
Like Tree1Likes
  • 1 Post By steve lee
Old   January 6, 2018, 16:11
Default Floating Point Segregated Flow Solver Error
bonztee is on a distinguished road
Hi
I have set up a rotational and translational body using RANS k-Epsilon. However when I start running the simulation I immediately get the following error:
A floating point exception has occurred: floating point exception [invalid operation]. The specific cause cannot be identified.
Context: star.segregatedflow.SegregatedFlowSolver
What should I look at changing?
Thanks.
bonztee is offline   Reply With Quote
Old   January 8, 2018, 09:44
Smile
ashokac7's Avatar
Ashok Chaudhari
ashokac7 is on a distinguished road
Send a message via Skype™ to ashokac7
You can start with reducing URF for the solvers. But if there is problem with mesh or solver set up then reducing URF will not work. So it is good practice to first check mesh, solver etc. Otherwise state detail problem and set up etc to comment more
ashokac7 is offline   Reply With Quote
Old   March 7, 2018, 03:55
patilsachin is on a distinguished road
This answer actually helped in another problem that I was working on with Segregated Energy Solver.
Reducing the URF did the trick
patilsachin is offline   Reply With Quote
Old   March 7, 2018, 21:52
Steve
steve lee is on a distinguished road
Hello.
You should check these things..
1. Mesh
2. Initial condition
if you can not find any problem #1 and #2, you should control URF.
still you find the same problem..
You should control B.C..
for example.. your problem has 100 bar pressure difference between in and out..
you set the pressure difference like 5 bar.. and after few steps.. 10 bar.. like this.
plokm107 likes this.
steve lee is offline   Reply With Quote
error, floating point error, segregated flow
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 14:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
Floating Point Exception Error nyox FLUENT 11 November 30, 2018 13:31
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 21:30
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 08:24
