Transient Particle Deposition Analysis
Like Tree2Likes
  • 1 Post By ashokac7
  • 1 Post By shydoz
Old   December 29, 2017, 09:48
Default Transient Particle Deposition Analysis
Shyam
shydoz is on a distinguished road
Hi all,
I am running an unsteady particle deposition analysis on a throat model. I am analysing the deposition of the particles on the wall boundary and I came across this on the tutorial guide for unsteady flows:
“In STAR-CCM+, it is possible to select the specific boundary interaction mode to control the outcome of a particle satisfying the adhere condition. The default in unsteady is Stick”
I was just wondering what the difference between this ‘’stick’’ condition and analysing the particle deposition using boundary sampling with the wall as the boundary.
Shouldn’t these two be showing the same thing because they are both monitoring when the particles contact the boundary?
Thanks in advance
shydoz is offline   Reply With Quote
Old   January 2, 2018, 04:15
Smile
ashokac7's Avatar
Ashok Chaudhari
ashokac7 is on a distinguished road
Send a message via Skype™ to ashokac7
Yes they should indicate same quantity. Boundary sampling is however more detailed. If you don't need detailed parcel property use stick option and report the particle scalar.
shydoz likes this.
ashokac7 is offline   Reply With Quote
Old   January 2, 2018, 09:01
Smile
Shyam
Hi Ashok,
Thank you for this .
I need detailed parcel property to see how it is contacting the boundary at different timesteps.
Do you know how to do boundary sampling at different timesteps? Currently my simulation is only showing boundary contact at the last timestep
ashokac7 likes this.
Old   January 2, 2018, 09:31
Smile
ashokac7's Avatar
Ashok Chaudhari
I think for this you have to switch on track file in Lagrangian model selection. I don't know exact procedure now but it can be done. I have to read to know exact procedure. You can find this on the Steve Portal. Just search for Boundary Sampling.
boundary, particle, star ccm+, transient, unsteady
UDF for particle interception with pt_termination fortran routine abcdefgh CFX 6 October 6, 2019 14:30
UDF for DPM particle deposition modelingpa haghshenasfard Fluent UDF and Scheme Programming 10 September 15, 2019 03:03
Importing solution from thermal steady state analysis to transient analysis david_1995 ANSYS 0 July 31, 2017 06:54
Cfx transient analysis maheshchamarti CFX 0 July 10, 2017 10:52
Transient analysis vikram92 ANSYS 0 March 15, 2017 05:38
