Heat transfer coefficient - local, specfied y+, standard??
Like Tree5Likes
  • 5 Post By ashokac7
Old   December 19, 2017, 15:58
Default Heat transfer coefficient - local, specfied y+, standard??
Akanksha Rawat
Akanksha90 is on a distinguished road
Hi users,
I understand the difference between the types of heat transfer coefficients, but I am confused which one to use to get the realistic htc. In the standard htc we can change the reference temperature and have the corresponding value. but should i use the local htc one? or the standard is the right one to use.
thanks
Akanksha90 is offline   Reply With Quote
Old   December 20, 2017, 07:56
Smile
ashokac7's Avatar
Ashok Chaudhari
ashokac7 is on a distinguished road
Send a message via Skype™ to ashokac7
Found this in one document. Hope this helps. My doubt are also cleared now.
When in doubt, use y+ reference htc.
The convective heat transfer coefficient (HTC) is defined as:
h= q''wall/(Twall-Tfluid)
• The only term not clearly specified is the fluid temperature, i.e. the
fluid temperature where?
• The choice of fluid temperature may be used to define different
– Some definitions may be more useful than others
– For turbulent forced convection, we would like the HTC to depend on the
Reynolds’ number, fluid properties and geometry
– There may also be some sensitivity to the type of boundary condition (i.e.
fixed temperature vs. constant heat flux), but the HTC should not depend on
the value of the boundary condition
– The above will be true only for particular choices of the fluid temperature
Heat Transfer Coefficient:
• Uses the computed wall heat flux, wall temperature, and a fluid temperature
specified by the user
• Does not account for local variations in fluid temperature
Local Heat Transfer Coefficient:
• Uses definitions from the wall treatment to compute a heat transfer coefficient
• These definitions effectively use the near-wall fluid cell temperature
• May have some sensitivity to near-wall mesh size
Specified y+ Heat Transfer Coefficient:
• Uses a fluid temperature at a specified y+ value
• Accommodates local fluid temperature variation effects
• Eliminates sensitivity to near-wall mesh size
• Recommended as best practice - combines the best features of the Heat Transfer Coefficient and the Local Heat Transfer Coefficient
Tobi-R, cwl, tisa and 2 others like this.
ashokac7 is offline   Reply With Quote
Old   December 21, 2017, 05:41
Akanksha Rawat
@ashokac7
Thank you very much it helped alot!
htc, y+ htc
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
