Turbulence model
Like Tree1Likes
  • 1 Post By MRI
Old   December 15, 2017, 09:22
Default Turbulence model
Farid Farid
Lattouf15 is on a distinguished road
I have to simulate a flow in 2.5m pipe with a diametre of 6mm.
I'm currently using K epsilon turbulence model, but the simulation keeps crashing for different mass flows of air. We're talking here of 2g/s, 1g/s and 0.66 g/s.
The goal is to calculate the pressure drop in the system.
Is there a specific turbulence model to use for small diametre pipes ?
Thanks
Lattouf15 is offline   Reply With Quote
Old   December 19, 2017, 07:52
MRI
Marco Riedel
MRI is on a distinguished road
Hello Farid,
k-eps should work. I think you have to look on your mesh. Try to calculate the distance of the first layer with that tool https://www.cfd-online.com/Tools/yplus.php and apply the wall distance of the first cell to your mesh.
If you consider y+ as 1 or smaller, then you should switch to the standard k-eps Model with Low y+ Wall Treatment. Generally you should avoid y+ Values between 1 and 30.
Best regard
mri
lcarasik likes this.
MRI is offline   Reply With Quote
cras, pressure and velocity, starccm+, turbulence
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Question about matching of solver and turbulence model louistse OpenFOAM Running, Solving & CFD 1 February 1, 2017 22:36
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Wrong calculation of nut in the kOmegaSST turbulence model FelixL OpenFOAM Bugs 27 March 27, 2012 10:02
