Kyle
Rep Power: 8 ![]() |
Hi, I'm new to using STAR-CCM+ as of today and I'm trying to run CFD analysis on a FSAE race car. I just was granted a power on demand license and am running into errors when starting a new simulation or project. The error I'm receiving when starting a simulation is as follows:
Design STAR-CCM+ simulation completed Server process ended unexpectedly (return code 8) I have the most recent version of STAR-CCM+installed on a Windows 7 computer. I've already gone into the firewall settings and allowed access through the 1999 and 2099 ports with no avail. Any help on getting started would be much appreciated! Thanks in advance. |
Rep Power: 24 ![]() |
This is not the full error, this is just the tail end of it. Every STAR-CCM+ session that exits abnormally says this. Please post the rest of the error.
Kyle
Sorted it out, thank you!
hanif
Rep Power: 0 ![]() |
hi udelfsae.. may i know how u sort it out? i have a problem with oepning starccm v12. it popped out "server process ended unexpectedly (return code-1073741790). your help very much appreciated!
Kyle
I had to delete some of the commands in the "command" input. Specifically I deleted -cpubind -shh -rsh and it worked after that.
Andreas Giannoulis
Hi everyone,
I am using ultraVNC user to connect to my university cluster to use Star-ccm+. When i try to open a new or an existing simulation the following error comes up: Starting local server: /opt/CD-adapco/12.02.010-R8/STAR-CCM+12.02.010-R8/star/bin/starccm+ -server -power -podkey IWXoAb48LNBbfP/jnUY3Sg -licpath 1999@flex.cd-adapco.com -rsh ssh Serial process 29251 STAR-CCM+ 12.02.010 (linux-x86_64-2.5/gnu4.8-r8) License build date: 10 February 2015 This version of the code requires license version 2017.02 or greater. Checking license file: 1999@flex.cd-adapco.com Error in checking out ccmppower: FLEXnet error: (-20001,147) Failed to get all licenses needed for this job. Asked for 1 licenses of ccmppower My licence works perfect on my own computer the problem comes up only when i try to use Star from the cluster. Note that the cluster is running on linux. Could someone help solve this? Thanks a lot in advance. |
You're using a power on demand license, so this means the cluster is having problems reaching the POD server (flex.cd-adapco.com). Look in the user guide for steps on ensuring the proper ports and whatnot are open on the cluster's firewall.
If that doesn't work you can always just set up an ssh tunnel to your machine and forward the port. |
#8 | |
Andreas Giannoulis
I dont know how but all of sudden it did work. Now I am facing a new problem as the following error comes up? Any clue? |
#9 |
Sachsen-Anhalt
#10 |
Rep Power: 7 ![]() |
I have the following error " server process ended unexpectedly (return code -1073741511)
Can anyone explain how the problem was solved. Thank you |
#11 |
Tamil Nadu
I have this error " server process ended unexpectedly (return code...)
How to fix this error. Kindly help |
#12 |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
As mentioned in the first response, every session that ends abnormally prints this message. Dump the contents of the console window if you want any assistance
#13 |
I got the return code 8 error. Not sure what to do. I attached an image of the full error message.
#14 |
Siddharth
THE BELOW ARE THE CONTENTS OF CONSOLE WHEN I TRY TO LOAD A FILE
PLEASE HELP ME Starting local server: starccm+ -server -rsh ssh "C:\\Users\\immor\\OneDrive\\Desktop\\Siemen\' s Star CCM+ course\\bike_save.sim" Serial process 11224 Simcenter STAR-CCM+ 2019.1 Build 14.02.010 (win64/intel18.3-r8) License build date: 09 November 2018 This version of the code requires license version 2019.02 or greater. Checking license file: F:\Siemens\license.dat 1 copy of ccmpsuite checked out from F:\Siemens\license.dat Feature ccmpsuite does not expire Error: Cannot open file: C:\Users\immor\OneDrive\Desktop\Siemen\'s Star CCM+ course\bike_save.sim (specify -new to create the file) Server working directory: 'C:\Users\immor\OneDrive\Desktop\Siemen's Star CCM+ course' Exit error: {'Neo.Error': 'Error', 'Path': 'C:\\Users\\immor\\OneDrive\\Desktop\\Siemen\\\'s Star CCM+ course\\bike_save.sim', 'Recoverability': 'Non-recoverable', 'ServerStack': ['SymInit: Symbol-SearchPath: \'.\', symOptions: 530, UserName: \'immor\'\n', 'OS-Version: 6.2.9200 () 0x300-0x1\n', '00007FF90BFD0211 (StarPlatform): (filename not available): StarCommandTokenizer::concatenate\n', '00007FF90BFEF608 (StarPlatform): (filename not available): Uuid::setFromStarString\n', '00007FF902654548 (StarNeo): (filename not available): NonRecoverableError::NonRecoverableError\n', '00007FF8FD013407 (StarMachine): (filename not available): Machine::startServerHost\n', '00007FF8FCFFF618 (StarMachine): (filename not available): Machine::main\n', 'ERROR: SymGetSymFromAddr64, GetLastError: 487 (Address: 00007FF76BF21EE0)\n', '00007FF76BF21EE0 (star-ccm+): (filename not available): (function-name not available)\n', 'ERROR: SymGetSymFromAddr64, GetLastError: 487 (Address: 00007FF76BF2FEAF)\n', '00007FF76BF2FEAF (star-ccm+): (filename not available): (function-name not available)\n', '00007FF94DC47BD4 (KERNEL32): (filename not available): BaseThreadInitThunk\n', '00007FF94F2ECE51 (ntdll): (filename not available): RtlUserThreadStart\n'], 'message': 'Cannot open file: C:\\Users\\immor\\OneDrive\\Desktop\\Siemen\\\'s Star CCM+ course\\bike_save.sim (specify -new to create the file)\nServer working directory: \'C:\\Users\\immor\\OneDrive\\Desktop\\Siemen\'s Star CCM+ course\'\n', 'severity': 'ERROR'} |
#15 |
Lucky
Apostrophes ' are illegal characters in filepaths
Just rename your folder Siemen's Star CCM+ course to something plainer. |
#16 | |
Harshi Bavishi
Rep Power: 6 ![]() |
cfd 2017 error, fsae, pod, power on demand, star-ccm+ |
[GAMBIT] Canīt start GAMBIT | zalho | ANSYS Meshing & Geometry | 18 | April 8, 2019 01:05 |
Start new Ansys Fluent automatically | Malue | Fluent UDF and Scheme Programming | 0 | September 28, 2017 10:53 |
What is the command to start a batch file with UDF? | h0rst | Fluent UDF and Scheme Programming | 1 | May 24, 2017 03:21 |
Start a crashed simulation from the iteration when it crashed. | alexskerhut | FLUENT | 0 | May 11, 2016 04:33 |
Lets start the public domain CFD-Project! | Heinz Wilkening | Main CFD Forum | 3 | March 11, 1999 22:55 |
