Controlling Y+ on Small Details
Like Tree1Likes
  • 1 Post By AndreP
Old   October 31, 2017, 19:03
Default Controlling Y+ on Small Details
InfernoxCJC's Avatar
Conor Crickmore
InfernoxCJC is on a distinguished road
Hello everyone,
I'm still pretty new to CFD so forgive me if I am missing something obvious on just being generally stupid.
I am working on a simulation of a reference vehicle model for use in a Wind Tunnel in STAR. The model utilises legs as opposed to wheels and the region has had to be refined to a pretty decent resolution just to be rendered correctly. The issue I am having is with the Wall Y+ on these legs, primarily where the leg meets the floor of the Wind Tunnel.
Using STAR's 'Near Wall Thickness' Prism Layer model, I have successfully resolved the main body of the model to a Y+ < 1 for use of the Low Y+ Wall Treatment, but these leg-floor boundaries are stuck in that undesirable 1 < Y+ < 30 region and I'm not sure how to proceed. Using ever smaller Near Wall cell sizes doesn't resolve the issue even as low as 1E-6.
Are there any other methods I can use to achieve a lower Y+ value? or at least boost these isolated regions to Y+ > 30? Perhaps by locally removing the Prism Layers entirely?
Thanks for your help!
InfernoxCJC is offline   Reply With Quote
Old   November 1, 2017, 07:15
André Pinto
AndreP is on a distinguished road
Originally Posted by InfernoxCJC View Post
Hello everyone,
If you remove the prism layers locally your Y+ will be too large. It depends how you're splitting your part. But if you have a separated part or surface for the feet, you can assign different sizes of the prism layers, and in that case, you can have a larger thickness or fewer prism layers locally! I think that fewer prism layers on the feet will do the trick for you!
InfernoxCJC likes this.
AndreP is offline   Reply With Quote
Old   November 4, 2017, 12:41
Conor Crickmore
Thanks Andre,
Before actually reading your post I had the idea to split the geometry into multiple Boundaries and utilised different thicknesses for each as you suggested, this (largely) resolved the issue!
[snappyHexMesh] .STL: non-closed manifold surface giulio.topazio OpenFOAM Meshing & Mesh Conversion 32 November 25, 2016 04:15
Introducing droneCFD -- Simplifying OpenFOAM simulations of small fixed wing aircraft capucsc OpenFOAM 3 October 17, 2014 07:22
Small timestep make the simulation not converge Anna Tian CFX 1 August 7, 2012 20:25
Do small boats slow big boats? Richard Scott Main CFD Forum 13 August 3, 2004 04:51
SGS small scales == fluctuant scales ?? Bin Li Main CFD Forum 6 February 26, 2004 13:35
