June 8, 2017, 06:33 |
Hydrostatic Pressure for a submerged body
Soroush Kargar
Rep Power: 9 |
Greetings
I have a rather simple question. I want to model a submerged body moving with speed of V in a depth of say 10 meters and want to neglect the free surface. Thus I don't want to activate the VOF Wave model. My question is: How to define hydrostatic/hydrodynamic pressure specially at boundaries? I rather say I want to it via a field function but am not very familiar with the syntax. Thus I don't know how to add position Z in the calculation. Best Regards |
June 15, 2017, 22:39 |
Ping
Rep Power: 20 |
by far the easiest way is to activate vof waves then define a flat wave but set the wave surface to be outside your fluid region so there will be no free surface created nor solved
then you can still use the inbuilt field functions on the boundary otherwise create field functions involving gravity and height which if z is vertical is $$Position[2] |
June 17, 2017, 06:11 |
Soroush Kargar
Rep Power: 9 |
Thanks for the reply
Yes in fact for such situations I have exactly done the method you said. So all I have to do is to add the position of Z in the form you mentioned. Thanks for the hint. |
question regarding LES of pipe flow - pimpleFoam | Dan1788 | OpenFOAM Running, Solving & CFD | 37 | December 26, 2017 14:42 |
static and hydrostatic pressure in incompressible solvers | sinatahmooresi | OpenFOAM Running, Solving & CFD | 1 | February 22, 2017 12:16 |
Calculate forces without hydrostatic pressure | geir_oye | FLUENT | 4 | November 12, 2009 09:12 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
Definition of pressure | Ola Nordblom | FLUENT | 1 | August 16, 2001 15:58 |
