Help for poor ship surface mesh (KVLCC2)
Like Tree3Likes
  • 3 Post By Seervan
Old   May 10, 2017, 04:20
Default Help for poor ship surface mesh (KVLCC2)
zhu zhang
zhuzhangkr is on a distinguished road
Hi, CFDers
Is there anyone who has experience in the ship problems?
I just started an analysis on KVLCC2 case but i met a problem on the imported surface mesh.
I used the .igs file which is published on Simman website and then imported the igs file into StarCCM as surface mesh. However, the surface seems imcomplete. So i tried to repair the surface but the repaired geometry is always problemsome.. this is quite frustrating...
Is there any advice? Using another cad problem to rebuild the ship geometry or other ideas?? Kind advice will be appreciatet!
zhuzhangkr is offline   Reply With Quote
Old   May 22, 2017, 15:26
Soroush Kargar
Seervan is on a distinguished road
Hey!
I had your problem either and I exactly know about your suffering (well coz I did!). igs files in SIMMAN arent quite well and after u download them u gotta mess with them in softwares like Rhino and stuff.
I am currently working on KVLCC2 right now and if u want, I can send u the corrected geometry which u can simply close the gaps and surfaces in STAR-CCM+ via Repair Surface Tool.
waiting to hear from you
Cheers!
zhuzhangkr, zjtcfd and Yongbo like this.
Seervan is offline   Reply With Quote
Old   June 8, 2017, 05:18
zhao jt
zjtcfd is on a distinguished road
Hi,Seervan
i always thought that it is my fault to get the igs files into wrong softwore before i see your answer. i meet the same qusetion too!
so, could you send me the corrected geometry? i am working on KVLCC2 for a long time.
Thank you very much!
zjtcfd is offline   Reply With Quote
Old   May 22, 2019, 11:10
Default NMRI geometry
dfz566 is on a distinguished road
A slightly better version of the KVLCC2 is available on
https://www.nmri.go.jp/institutes/fl.../kvlcc_g&c.htm
dfz566 is offline   Reply With Quote
Old   May 27, 2019, 10:19
Default Still poor quality of KVLCC2
even the recently posted geometry causes severe meshing issues in the simulation programs I use. Is there anyone who could send me a better geometry of the KVLCC2 hull?
Best regards,
Carl
Originally Posted by PinkFloyd View Post
Hello hello hello hello,
is there anybody out there? Just nod if you can hear me. Is there anyone at home?
kvlcc2, ship
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[snappyHexMesh] Problem with Sanpper, surface still Rough Zephiro88 OpenFOAM Meshing & Mesh Conversion 7 November 5, 2014 13:05
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
