Turbulence Kinetic Energy Residuals not converging
Like Tree2Likes
  • 2 Post By MRI
Old   May 3, 2017, 09:54
Default Turbulence Kinetic Energy Residuals not converging
gemxx
gemxx is on a distinguished road
I want to ask a question about Residuals.
I study on the noise around a circular cylinder but the residual values of turbulence kinetic energy is not converge. I use k-omega turbulence model.
What is the reason of this ? Could you please help me about this matter ?
I upload the picture of the residuals and mesh structure in attachment. (It belongs to steady state simulation.)
gemxx is offline   Reply With Quote
Old   May 3, 2017, 11:57
MRI
Marco Riedel
MRI is on a distinguished road
The Tke does converge but with high residuals. Please switch off the "Normalization Option" under the monitor node for all residuals and then have a look on the residuals.
gemxx and Ali Soleimani like this.
MRI is offline   Reply With Quote
Old   May 3, 2017, 16:48
gemxx
Thank you very much for your reply. I switched off the "normalization option" under the monitor node for all residuals and then the Tke residuals decreased.But now the standard deviation of residual energy (sdr) is too high.
I added in attachment the picture of residuals at the final state.
what is the significance of "normalization option" in monitor properties? Do you think that all residuals are converge ? Can I see the residuals are converge or not by using another way ?
Old   May 3, 2017, 17:11
gemxx
I also added the maximum Tke value and the sum of Tke on the circular cylinder.
Old   May 4, 2017, 03:41
MRI
Marco Riedel
As a next step I would have a look at the wall y+ values on the cylinder surface. Try to lower them below one (by decreasing the wall distance of the first cell next to the wall) and switch on a low-y+ wall treatment in the physical models and start calculating again. To calculate the wall distance you can use this tool https://www.cfd-online.com/Tools/yplus.php
turbulence kinetic energy k boundary condition at walls cookcaptain OpenFOAM Programming & Development 0 April 5, 2017 06:05
Turbulent kinetic energy in k-epsilon model khunyeu FLUENT 0 October 7, 2013 02:31
How to exclude UDFs and turbulence kinetic energy source terms? bryanwly Fluent UDF and Scheme Programming 0 May 22, 2011 14:01
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
Why FVM for high-Re flows? Zhong Lei Main CFD Forum 23 May 14, 1999 14:22
