User Field Functions
Like Tree1Likes
  • 1 Post By me3840
Old   November 29, 2016, 11:58
Default User Field Functions
Goldenballs is on a distinguished road
Hi All,
I have never programmed in C before and thus am struggling with writing a user field function. I would like to write a function to determine spray penetration length. Something like:
"If (Volume fraction < X), return the max position in Z where this occurs"
I have so far:
(${LagrangianVolumeFractionPhase 1} < 0.75) ? max($${Position}[2])
However I get syntax errors and generally have no idea how to write it. Could anyone help me out?
Thank you.
Goldenballs is offline   Reply With Quote
Old   November 29, 2016, 13:36
me3840 is on a distinguished road
You don't use field functions for this. Field functions make 1 value for each cell in the entire field, hence the term field function. You want to return just 1 value. That's a report.
You want to make a threshold of volume fraction < 0.75. Then make a maximum report on that threshold of position in Z. Run the report and you get your value.
kirrer likes this.
me3840 is offline   Reply With Quote
Old   November 30, 2016, 10:28
Lucky
I concur. Don't use a field function, unless you're trying to define a field.
Old   December 6, 2016, 10:37
Thank you both, threshold worked, all be it a bit crude.
I do have a couple of questions with regards to volume fraction, if you wouldn't mind?
I does the "volume" refer to the mesh cell size at that location? Other than the cell size, are there any key contributors to such a low (~0.0008) volume fraction, when I was expecting something in the order of 75%?
Thanks.
Old   December 6, 2016, 12:06
Volume does refer to the volume of the cell. There are only two components to the volume fraction - the volume and the phase. If your volume is an expected size then whatever is producing the phase is the problem.
syntax, user code, user field function
How to calculate pressure forces using custom field functions? tsagaro FLUENT 7 June 23, 2017 16:45
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
''unknown radialModelType type Gidaspow'' PROBLEM WITH THE BED TUTORIAL AndoniBM OpenFOAM Running, Solving & CFD 2 March 25, 2015 19:44
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Custom field functions sivakumar FLUENT 1 October 12, 2001 07:36
