Running transient with steady results as initial conditions |
November 24, 2016, 12:46 |
Chaotic Water
Rep Power: 18 |
Hi
To my great embarrassment i found out - that i do not know any easy way to run transient simulation using steady run results as initial conditions (same simulation, same physics etc). Obviously i can change physics from steady to unsteady, but i want it to run from very beginning to the end without my interference i.e. manual switching or recording any macro (Run steady -> Converge -> Switch physics -> Run transient) - so i'm pretty sure there is much easier and natural way. Please, tell me i'm an eejit and give a hint %> |
November 28, 2016, 18:17 |
Rep Power: 25 |
No, there is no non-manual intervention for this. The best way is to write a macro.
You can in theory set a large timestep with a huge number of inner iterations and then reduce it once the 'steady' part converges with a field function, but I would recommend using the macro. |
November 29, 2016, 05:06 |
Chaotic Water
Rep Power: 18 |
Thank you for you reply :>
That's awful, even CFX has got this feature :-\ Yep, macro will work, - but will make life a bit more complicated in case of automated runs like Optimate. |
November 29, 2016, 09:17 |
Rep Power: 25 |
Optimate has a feature to allow a macro to run during the run, so it shouldn't be a big deal.
November 29, 2016, 10:31 |
Chaotic Water
Rep Power: 18 |
It's not a big deal, it's another minor issue - instead of setting a kind of "computational sequence" in Star (like Solve Steady -> Solve Transient), there is a need to use macro.
I just mean that unnecessary complexities better be avoided. I'm pretty sure - we'll see this feature in the nearest future .. although it took few years to implement different colors for bodies in CAD-editor |
HeatSource BC to the whole region in chtMultiRegionHeater | xsa | OpenFOAM Running, Solving & CFD | 3 | November 7, 2016 06:07 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 16:33 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 07:37 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 06:24 |
