Multiphase simulation
Like Tree1Likes
  • 1 Post By Roman
Old   November 20, 2016, 09:15
Default Multiphase simulation
Vyacheslav
Vyacheslav is on a distinguished road
Hi everyone, I need your help!
The task is multiphase simulation of air and water flow with a given law of solubility of the air in the water(depending on some field function, eg pressure). Is it possible to carry out?
Vyacheslav is offline   Reply With Quote
Old   November 20, 2016, 10:04
Roman
Roman is on a distinguished road
Yes! Sounds like a problem I would use VOF wave models for. However, it's hard to suggest a solution without knowing exact details of your needs and goals.
Roman
Roman is offline   Reply With Quote
Old   November 20, 2016, 10:17
Vyacheslav
Actually all of the details are given) For example use a pipe with a gas-liquid mixture on its inlet. Due to hydraulic losses pressure decreases along the pipe and the liauid exudes more gas. Assume the gas concentration is in inverse ratio to the pressure.
Old   November 20, 2016, 13:13
Roman
Sounds like VOF model is the right way to go then.
Take a look at "VOF Formulation > Gas Dissolution and Cavitation Formulation" section in the Star manual to get an idea for what gas dissolution model suits your case better.
Roman
lcarasik likes this.
Old   November 20, 2016, 17:40
Vyacheslav
That sounds reasonably, but where have you found Gas Dissolution and Cavitation Formulation? The only thing I managed to find is Cavitation Formulation in phase interaction models and it doesnt seem to aloud me to bring in any changes.
Old   November 21, 2016, 02:41
Roman
In the user manual. The exact path in the manual tree is:
User Guide > Modeling Physics > Modeling Multiphase Flow > Using the VOF Multiphase Model > VOF Formulation > Gas Dissolution and Cavitation Formulation
I'm using Star-CCM+ 11.06.010
air solubility, multiphase flow, solubility law
Multiphase heat exchange simulation efer2109 STAR-CCM+ 1 September 15, 2016 14:22
about Lagrangian Multiphase Simulation jhlee9622 STAR-CCM+ 0 March 18, 2015 02:38
Probelem in simulation of multiphase neetu kumari Main CFD Forum 0 March 26, 2012 04:24
Single phase result file for multiphase simulation Kushagra CFX 2 July 8, 2008 22:14
multiphase simulation... 2D flow through an elbow Tim CFX 10 April 3, 2008 19:13
