If model enabled, java macro
Like Tree1Likes
  • 1 Post By taillanm
Old   November 7, 2016, 10:45
Default If model enabled, java macro
taillanm is on a distinguished road
Hi all,
For postprocessing purposes of many cases I want to use one macro to extract information depending on certain conditions, here which physics model is used: inviscid or not.
At the moment my macro looks like:
if ( physicsContinuum_0.getModelManager().hasModel(Invi scidModel.class) = true) {
do stuff }
else { do stuff }
I have troubles debbugging the last method hasModel(..) and the true condition; replacing it by enabled didn't help..
In the case of ... = true the error says that i need a variable and not a value.
Did anyone come across something similar once?
Thanks
taillanm is offline   Reply With Quote
Old   November 7, 2016, 13:15
Kevin
kirrer is on a distinguished road
There are a few ways (methods) to check whether the model is contained. First, a comment - inside the if statement, you need two equal signs to check whether two objects are the same. So if you wanted to check whether 2 is equal to 1+1, you need to write:
 if(2==(1+1))
Only 1 equal sign will attempt to assign one value to another - in this case, 2=(1+1) would attempt to assign the value of (1+1) to the integer 2, which does not make sense.
To address your question directly, many methods for checking what models exist return a Model object themselves. I would avoid those methods for the simpler .has() method, which lets you specify a string. This macro works to achieve what you want:
// STAR-CCM+ macro: CheckInviscidModel.java
// Written by STAR-CCM+ 10.06.010
package macro;
import star.common.*;
public class CheckInviscidModel extends StarMacro {
  public void execute() {
    execute0();
  private void execute0() {
    Simulation simulation_0 =
      getActiveSimulation();
    PhysicsContinuum physicsContinuum_0 =
      ((PhysicsContinuum) simulation_0.getContinuumManager().getContinuum("Physics 1"));
    if(physicsContinuum_0.getModelManager().has("Inviscid")) {
        simulation_0.println("has inviscid model!");
    } else {
        simulation_0.println("does not have inviscid model!");
kirrer is offline   Reply With Quote
Old   November 8, 2016, 03:39
[QUOTE=kirrer;624530] ".has() method "
Hi Kevin, many thanks for this post I will try it out now. Actually I tried also something else yesterday that works but is a bit longer:
Collection<Object> models = physicsContinuum.getModelManager().getChildren();
String Modelnames = models.toString();
Boolean Inviscid = Modelnames.contains("Inviscid");
if (Inviscid == true) {
// do stuff }
and Indeed as I am writing this, your line works well ;-)
kirrer likes this.
if condition, java macro
Error in Two phase (condensation) modeling adilsyyed CFX 15 June 24, 2015 20:42
manualInjection model in sprayFoam Mentalo OpenFOAM Running, Solving & CFD 1 April 2, 2014 10:29
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 26, 2009 00:27
