Ahmed Mohamed
Rep Power: 11 ![]() |
Hi everyone,
I have worked to achieve my project by using fluent but I have to switch to star ccm+. I use LES to solve two phase air-water flow. I understood that converting from tetrahedral to polyhedral will decrease the skewness and improve the meshing quality. My question can I switch to polyhedral from tetrahedral which I used it in the fluent file? does that effect the geometry or need to create computational domain by star ccm instead that used in fluent? Thanks for all. |
#2 | |
Lane Carasik
Rep Power: 15 ![]() |
Ahmed Mohamed
thanks Lane very much for your reply, I appreciate your effort and your cooperation.
Just to let you know that I create my geometry which is simple but I need to refine certain volume through cubic volume that I failed to achive it by star ccm so I switched to ICEM instead to create this geometry and refine the mesh. my question is can I import the icem file before meshing to star ccm or as some people advice me I have meshing it by ICEM and Create FLUENT file then import it to star ccm? Thanks so much Lane. Last edited by Afaraj; August 21, 2016 at 16:05. |
#4 | |
Ahmed Mohamed
Just to let you know that I create my geometry which is simple but I need to refine certain volume through cubic volume that I failed to achive it by star ccm so I switched to ICEM instead to create this geometry and refine the mesh. my question is can I import the icem file before meshing to star ccm or as some people advice me I have meshing it by ICEM and Create FLUENT file then import it to star ccm? Thanks so much Lane. |
#5 | |
Arjun
Rep Power: 34 ![]() ![]() |
export in fluent 6 format
and import 'volume mesh' in ccm Quote:
#6 | |
Lane Carasik
Lucky
Rep Power: 66 ![]() ![]() ![]() |
Personal preference matters. Importing isn't a problem, so use whatever you like. I prefer the ICEM mesher over the Star-CCM mesher any day. Star's meshing algorithm went on a fork early in its history and tends to produce 'ugly' meshes. The way it retracts prism layers is such a huge annoyance. It also likes to throw all the skewed cells right at the prism layer and core mesh interface, the worst place to put them.
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 06:42 |
Problem compiling a custom Lagrangian library | brbbhatti | OpenFOAM Programming & Development | 2 | July 7, 2014 11:32 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 13:59 |
2.0.x on Mac OSX | niklas | OpenFOAM Installation | 74 | March 28, 2012 16:46 |
