3D CAD airfoil geometry using star-ccm+
Like Tree1Likes
  • 1 Post By marmot
Old   July 21, 2016, 16:40
Default 3D CAD airfoil geometry using star-ccm+
meem is on a distinguished road
Hi, I have made a 3D airfoil part using star-cm+ own 3d CAD. I plan to change the orientation of the airfoil by changing its angle of attack after mesh generation. Will I have to regenerate the mesh after changing the angle of attack each time? This is my MSc project and I am quite new to cfd, help is much appreciated.
meem is offline   Reply With Quote
Old   July 22, 2016, 04:52
kevin alun
marmot is on a distinguished road
Yes you can make it a parameter in the CAD model and if you setup the work flow it becomes a simple remesh/ new run but you can also rotate your region for each new angle, you should be using a c-grid shape for your domain,
meem likes this.
marmot is offline   Reply With Quote
Old   July 22, 2016, 08:51
thank you marmot. With your guidance I was able to find all the details in star-ccm+ tutorials.
3d cad, airfoil
Saving geometry after adjoint optimisation/Save mesh as CAD edcfd FLUENT 1 December 11, 2023 05:43
Problem with airfoil shape optimization robyTKD SU2 Shape Design 7 March 7, 2022 17:18
Problem with restart solution in shape_optimization.py robyTKD SU2 Shape Design 21 May 29, 2013 10:26
[GAMBIT] NACA6512 Airfoil geometry orion ANSYS Meshing & Geometry 0 October 19, 2011 13:22
Airfoil Geometry Chan Main CFD Forum 1 August 12, 2003 03:51
