Multiphase (gas-liquid-solid-ions) reactions using VoF model |
June 29, 2016, 16:13 |
Dursman Mchabe
Rep Power: 11 |
Hi everyone
I am a newbie in STAR-CCM+. I would like to ask if it is possible to simulate multiphase (gas-liquid-solid-ions) reactions using VoF model. The example of such set of reactions (as it occurs in wet FGD systems) is: (i) SO2(g) <=> SO2(aq) (ii) SO2(aq) + H2O <=> H2SO3 (iii) H2SO3 <=> H+ + HSO3- (iv) HSO3- <=> H+ + SO32- (v) CaCO3(s) <=> CaCO3(aq) (vi) CaCO3(aq) <=> Ca2+ + CO32- (vii) H+ + CO32- <=> HCO3- (viii) H+ + HCO3- <=> CO2(aq) + H2O (ix) Ca2+ + SO32- <=> CaSO3(s) My objective is to use STAR-CCM+ to determine the mole fractions (for every time-step) of SO2(aq), H+, HSO3-, SO32-, Ca2+, HCO3-, CO32-, CO2(aq) and CaSO3(s). When SO2(g) is absorbed into limestone slurry, the above-listed reactions are considered to take place. Kind Regards GD |
June 30, 2016, 02:18 |
kevin alun
Rep Power: 15 |
I think they are working on a multi-component multi-phase ability but perhaps for now you select multi-phase VOF and within one of your phases you introduce passive scalars, create your source terms between passive scalars,
Problems may arise at the interface, its possible there is nothing to prevent your passive scalar from appearing in the gas phase, or you try to do a sink/source term for interface cells but its not trivial |
Using VOF model and Lagrangian Multiphase in the same simulation | ganesh_krishnan | STAR-CCM+ | 2 | March 17, 2017 02:34 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
urgent... multiphase cfd model of packed bed reactor.( VOF MODEL using) | balu@gold6 | FLUENT | 4 | July 26, 2012 11:37 |
Define initial liquid level for VOF model | Gab | CFX | 2 | May 10, 2007 00:42 |
Moving mesh or VOF? | Giovanni | Main CFD Forum | 16 | September 24, 2001 09:25 |
