June 25, 2016, 15:20 |
limited temperature in X cells
Rep Power: 10 |
I have following problem: After I start my simulation I get the following warnings: "temperature corrections limited in X cells" and "temperature is set to minimum". I created a treshold in a scene and looked in different time states, where these "bad" cells were. But they were always on different places. I checked the mesh quality and there I got no invalid cells with the default settings. Also my time step and my under relaxation factors are pretty low. I dont understand why the temperature is limited ? Can somebody explain it to me and maybe give me a solution to this problem? |
June 26, 2016, 01:10 |
kevin alun
Rep Power: 15 |
When solving the energy equation there is no numerical limit on temperature, thus in references you can find where you set a hard limit min/max, similar to passive scalar equation you also set a min/max.
When running steady-state this is not really an issue when you get this error message at the start up, most likely it goes away unless you have really bad cells and you have an energy source term or flux boundary near them For transient it could mean you have a bad initial guess on temperature, say you initialize with 20C but have an inlet boundary with 500C, Check your initial conditions or run steady to get a flow/temperature field and than start transient, |
June 26, 2016, 05:40 |
Rep Power: 10 |
Thank you for your answer!
Unfortunately this warning doesnt go away and I get a problem with my combustion. It doesnt burn because the temperature is to low due to the limited temperature cells . I will try to run steady. (my current state is implicit unsteady) What do you mean by checking my initial conditions? Under continuum>initial conditions there are only a few selections like the initial pressure (~1bar) and my initial temperature(~300K). |
June 27, 2016, 01:29 |
kevin alun
Rep Power: 15 |
You can change the upper limit on the maximum temperature, although I think it is 2000 or 5000K by default,
Under continuum>reference values Boiling is more my topic but perhaps it has more to do with the combustion model, rate, concentration, etc. that is the underlying problem not the min/max limits on temperature. |
[openSmoke] libOpenSMOKE | Tobi | OpenFOAM Community Contributions | 562 | January 25, 2023 09:21 |
TEMPERATURE LIMITED problem | emanuele | FLUENT | 9 | June 15, 2018 10:45 |
Temperature limited to 1k in so many cells in domain 1 | swapnilnid | CFD Freelancers | 1 | February 26, 2016 19:25 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 01:27 |
Too low temperature at combustor outlet | romekr | FLUENT | 2 | February 6, 2012 10:02 |
