Urgent.....Dispersed Multiphase flow simulation
Like Tree1Likes
  • 1 Post By mohammad
Old   June 19, 2016, 02:58
Question Urgent.....Dispersed Multiphase flow simulation
mohammad
mohammad is on a distinguished road
Hey Guys,
I am trying to simulate air dust circulation inside a room in a presence of an air injector using DMP. The initial dust VOF is 5%. I set the simulation according to the STAR CCM 9.06 manual. The problem is when I initialize the simulation, the initial dust VOF contour is ok (showing 5%) and also the total volume of the dust (using Volume Integral) particles is ok (0.05*Room Volume=1.39 m^3).
However, when I run the file, immediately after the first timestep the values of dust VOF dorp to 0.01 and also the total dust volume of dust inside the room follow the same trend and become one-fifth ((1/5)*1.39m^3=0.278 m^3).
Amazingly, the value of 0.01 (and also the total dust volume inside the room ) do not chang even if I use ANY OTHER INITIAL DUST VOF....
any idea?!!!
mohammad is offline   Reply With Quote
Old   June 19, 2016, 03:14
mohammad
Very amazingly, even when I change all of the INLETs and OUTLETs to WALL, still the same thing and the same values show up....
Old   June 21, 2016, 22:07
Default Answer
mohammad
Answer to my previous question
The reason of jumping to VOF of 0.01 is that this value is a predefined value under
SOLVER> DISPERSED MULTIPHASE> VOLUME FRACTION
then you need to change the "Maximum Volume Fraction" to any higher value if your simulation includes a higher VOF than 0.01.
Farzam likes this.
dmp
Simulation of Multiphase Flow (Particle re-suspension using a mechanical device) jenny_kapoor FLUENT 0 May 23, 2016 19:43
Multiphase flow with two continuous fluids and one dispersed fluid ashtonJ CFX 5 July 25, 2014 07:31
Differences and functions of Solidworks Simulation and Solidworks Flow Simulation? alpharays Main CFD Forum 0 April 19, 2012 04:13
Simulation of multiphase liquidliquid flow in_flu_ence OpenFOAM Running, Solving & CFD 1 March 13, 2007 03:11
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
