Bath run with a macro (linux)
Like Tree2Likes
  • 1 Post By harry123
  • 1 Post By me3840
Old   May 19, 2016, 10:07
Default Bath run with a macro (linux)
Jens
Hqjen is on a distinguished road
Hello all
I need to change some values of ~200 files, which are then run in batch.
I have recorded a little macro for changing these values, but how to batch-run both the simulations and the macro ?
something along the line of
"starccm+ -batch -np 4 -podkey key -licpath path -power MyMacro.java File(number).sim;
The batch command however just runs the macro. How do i achieve
loading simulation--->chaning values via macro--->running the changed simulations
in a batch environment?
HQjen
Hqjen is offline   Reply With Quote
Old   May 19, 2016, 11:22
harry123 is on a distinguished road
start recording the macro, change your required values and start the run. Stop it after few iterations and stop recording the macro.
Your macro would now have a line like this at the end:
simulation_0.getSimulationIterator().run();
Running this macro would then run your simulation after making changes in values.
Hqjen likes this.
harry123 is offline   Reply With Quote
Old   May 19, 2016, 11:36
Jens
Thanks for the reply. Indeed, "simulation_0.getSimulationIterator().run();" is present in the macro.
However,
If i specify -macro in the .sh file, it opens the gui, which is not preferable.
If i specify -batch, i cant seem to open both the .sim file, and the macro.
How would i get around this?
Old   May 19, 2016, 19:31
me3840 is on a distinguished road
The correct batch command is:
starccm+ -batch -np 4 -podkey key -licpath path -power -batch MyMacro.java File(number).sim
the java macro is the argument of the -batch flag.
Hqjen likes this.
me3840 is offline   Reply With Quote
Old   May 20, 2016, 13:01
Jens
That did the trick. Problem solved, thank you!
Run Multiple Files in Batch nickninevah STAR-CCM+ 6 October 12, 2017 07:17
Help with executing macros at specific timesteps during the solution run Codophobia Fluent UDF and Scheme Programming 1 April 28, 2014 07:16
Parallel run of OpenFOAM in linux and windows side by side m2montazari OpenFOAM Running, Solving & CFD 5 June 24, 2011 04:26
Dual Boot Windows and Linux and Go Open Source andyj Main CFD Forum 2 October 21, 2010 17:49
Errno 24 linux ivanwhlau OpenFOAM Running, Solving & CFD 6 July 1, 2009 11:16
