Floating Point Error Segregated flow solver
Like Tree4Likes
  • 1 Post By willful
  • 3 Post By marmot
Old   May 13, 2016, 05:34
Default Floating Point Error Segregated flow solver
William Fulwood
willful is on a distinguished road
I'm trying to model flow from an air vent onto a body and have run into an error when running the solution:
Error: AMG solver diverged.
A floating point exception has occurred: floating point exception [Invalid operation]. The specific cause cannot be identified. Please refer to the troubleshooting section of the User's Guide.
Context: star.segregatedflow.SegregatedFlowSolver
Command: RunSimulation
error: Server Error
I have tried increasing time step and decreasing the under-relaxation factor for the segregated solver with no luck. This is for a project I must write up soon so any help would much appreciated
Balele likes this.
willful is offline   Reply With Quote
Old   May 13, 2016, 09:57
kevin alun
marmot is on a distinguished road
Check your mesh quality,
Make sure cell quality remediation is on your physical models
Check for non-continuous cell groups
Does it happen after the 1st iteration or very soon, than look at initial conditions
if it is happening later, try to monitor things like max velocity or turbulence values and stop the run, create a threshold and examine the mesh in those area,
not so good but you can try, 1st order,
have fun,
Eike, Sandy7 and Balele like this.
marmot is offline   Reply With Quote
Old   May 13, 2016, 15:36
William Fulwood
It was happening after the first iteration however i have reimported the surface mesh and run through the whole process a bit "cleaner" and i seem to have it working now
Thanks for your help though
floating point segregated
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 08:54
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
3d vof Smaras FLUENT 2 February 19, 2013 07:58
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 03:27
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
