VOF method
Like Tree1Likes
  • 1 Post By marmot
Old   April 18, 2016, 09:15
Default VOF method
harry123 is on a distinguished road
I'm doing a water jet simulation using the VOF method. When I reduce the time step size of the simulation or make the grid finer, the results obtained becomes worse. I would have guessed by making grid finer, I should get better results. Am I wrong ?
I use RANS turbulence model, Eulerian Multiphase, VOF, implicit unsteady.
The simulation seem to be quite sensitive to change in time step size also, is it normal for VOF simulations or would I be doing something wrong ?
harry123 is offline   Reply With Quote
Old   April 24, 2016, 17:13
Jonny
Jonny6001 is on a distinguished road
Interesting question
Jonny6001 is offline   Reply With Quote
Old   May 6, 2016, 11:48
Asking again since no reply was found !!
I have attached the plot of variation of water volume phase along axis and experimental data from journal is plotted alongside.
Can someone give a clue please ?
Old   May 8, 2016, 04:10
kevin alun
marmot is on a distinguished road
There is a link between mesh size, time step and number of inner iterations. 1st you need to make sure you have somewhat of a good convergence before going to the next time step. Next you need to make sure your VOF surface is not moving more than 1 or 2 cells in a time step, than you get smearing and have to use this sharpening factor. I found it better to have smaller time step, less inner iteration, ~5, rather than large time step and 20 inner iterations. So you need to look at how the VOF surface is moving for the mesh density you have.
VOF is fun but it does take time.
You should also read about CFL_l and CFL_u, if you make them larger in theory your vof surface could travel more than 1 or 2 cells but than sharpening factor should be turned on.
harry123 likes this.
marmot is offline   Reply With Quote
Old   May 25, 2016, 12:21
Default Geo-Reconstruction/InterfaceCompression/CICSAM
JIM SU is on a distinguished road
Dear OF user's,
Please anyone tell me if at OP 2.1 or 2.3 which the better schemes of discretization, I have to reconstruct the interface when are solving the gamma equation for two-phase flow. I would like to know if OP have a similar Geo-Reconstruct or CICSAM scheme discretization implemented on Fluent or maybe have a better scheme. I have seen in the literature that the interfaceCompression scheme includes more smear on interface , Is it true?
My kind regards
JIM SU
JIM SU is offline   Reply With Quote
vof, water jet
How to apply heat flux at the interface when using VOF method? princekar FLUENT 0 November 15, 2015 08:47
two phase flow using vof method saketh9187 FLUENT 0 January 10, 2013 06:50
VOF vs LSM Numerical Method ck5285 Main CFD Forum 2 July 21, 2009 08:21
Re: VOF method Ernie Main CFD Forum 0 December 1, 2006 14:13
Moving mesh or VOF? Giovanni Main CFD Forum 16 September 24, 2001 09:25
