Intial water-air conditions Mixing tank
Like Tree1Likes
  • 1 Post By Rob87
Old   March 1, 2016, 11:35
Exclamation Intial water-air conditions Mixing tank
SCR
Sonny Calderon
SCR is on a distinguished road
I'm trying to do a simulation of a mixing tank that is partially filled stirred by and impeller. I have set the physics model to be a multiphase eulerian model and have already set both phases (Water on bottom and AIR on top) and put the intersection as an continuous-dispersed intersection, water being continuous and air dispersed. I don't know if this is correct since the air is on top of the water. My main problem is that I do not know how to specify the level of water in the tank. It most be a simply thing to do but I'm new to the software and all I've done has been with the user guide. If you have any comments that are not related to the water level that might help with the simulation I'd be very grateful.
Thank you!
SCR is offline   Reply With Quote
Old   March 31, 2016, 05:59
harry123 is on a distinguished road
You can have a look at the cavitation tutorial. They specify water to left side of domain and air to right using Field Functions. Guess you can do something simliar, I'm also new to starccm, so I'm not sure if this is the standard easiest method.
Tutorials > Multiphase Flows > VOF Cavitation > Setting initial conditions
harry123 is offline   Reply With Quote
Old   March 31, 2016, 08:54
Robert Gottschalk
Rob87 is on a distinguished road
as harry123 said you have to create two field functions. One is for water and one for air. Thats what I use:
($$Centroid(@CoordinateSystem("Laboratory.Cylindri cal 1"))[2]<=0.001)? 1:0
first you have to refer to a coordinate system if you not wanna use the original one. The [2] represant the z coordinate. After the bracket comes the value you one use. The first on is used when your formulation in the brackets is true. Otherwise the second value will be used. You need the same field function for air again. Just chance the 1 with the 0.
At last you have to select this function in the physics node.
harry123 likes this.
Rob87 is offline   Reply With Quote
eulerian multiphase, intersection, mixing tank, multiphase flow
No liquid water exist in my Fuel Cell simulation fatchang FLUENT 19 October 15, 2018 15:27
air into box filled with water, outflow for water at bottom dieterdanger Fluent Multiphase 0 July 16, 2015 17:11
Simple Water Tank Transient 88phil88 CFX 5 March 17, 2014 04:48
Boundary conditions for water jet into air in a closed chamber vishal_s OpenFOAM Running, Solving & CFD 0 August 20, 2013 04:27
Simulating air injecting to water in a tank? Howard Wang Main CFD Forum 6 March 13, 2009 22:32
