How to calculate Reynolds shear stress of a fully turbulent channel flow
Like Tree1Likes
  • 1 Post By LuckyTran
Old   February 29, 2016, 12:00
Default How to calculate Reynolds shear stress of a fully turbulent channel flow
UK
yansheng is on a distinguished road
Dear experts,
I was doing a validation test of a fully turbulent plane channel flow. From the literature, it is obvious that velocity, turbulence intensity and Reynolds shear stress are the most important statistics that anyone who is doing turbulent flow analyzing will calculate. However, I was wondering how to calculate the Reynolds shear stress in Star-ccm+. Some example graphs are attached below from John Kim (1986), Turbulence statistics in fully developed channel flow at low Reynolds number.
Best regards,
Yansheng
yansheng is offline   Reply With Quote
Old   March 8, 2016, 18:35
Lucky
Reynolds stresses are absolutely paramount, complete knowledge of the Reynolds stresses at every x,y,z will close the RANS equations. The only difference between one turbulence model and another is the Reynolds stresses (and experiment). If you want to unambiguously compare results, then the Reynolds stresses are the only way to do so.
It varies widely depending on the models how to compute them:
If you are doing LES then you can brute force calculate the Reynolds stresses.
If you are using a Reynolds stress model then the Reynolds stresses are available, but they will be modeled.
If you are using an eddy viscosity model, then you will have to calculate the Reynolds stresses yourself by using the Boussinesq eddy viscosity hypothesis (+ the strain rate & the turbulent viscosity). You will need to setup new field function definitions.
yansheng likes this.
calculate y+ and u+ -how to get wall shear stress? Ralf Schmidt Main CFD Forum 18 September 17, 2019 04:23
How to calculate turbulent shear stresses danielec87 OpenFOAM 0 August 30, 2012 19:25
Calculate velocity components from shear stress Arnoldinho OpenFOAM Running, Solving & CFD 0 August 29, 2011 13:07
interFoam - stratified flow - problem with shear stress at interface AnjaMiehe OpenFOAM Running, Solving & CFD 8 June 14, 2010 07:49
how to calculate CFL number in 3D convection-diffusion channel flow dryhill Main CFD Forum 0 June 24, 2009 04:33
