December 13, 2015, 13:20 |
No 'split by patch'?
Rep Power: 11 |
I want to split the surfaces in a new part in a sim file using 'split by patch' option, but it is GREYED-OUT in the menu - I don't know why and it's driving me nuts!
It was working fine before, but I don't know what I've changed in the sim file to make the option unavailable. |
December 14, 2015, 11:11 |
Kevin
Rep Power: 13 |
You need to have a scene open from that same sim file in order for "Split by patch" to be available. It can be an empty or completely unrelated scene, but CCM+ needs somewhere to show the patches and let you click them. The same thing happens when you try to "Edit in Current Scene" (for some derived parts).
I'm not sure why the default action is not to just create an empty scene, but that's how it's programmed. |
December 14, 2015, 16:30 |
#3 | |
Rep Power: 11 |
(sometimes it's those simple obvious little things that actually aren't so obvious) |
[Other] Wedge patch '*' is not planar | LilumDaru | OpenFOAM Meshing & Mesh Conversion | 7 | Yesterday 05:52 |
y+ and u+ values with low-Re RANS turbulence models: utility + testcase | florian_krause | OpenFOAM | 114 | August 23, 2023 05:37 |
Near wall treatment in k-omega SST | Arnoldinho | OpenFOAM Running, Solving & CFD | 38 | March 8, 2017 13:48 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
