November 24, 2015, 16:01 |
meshing geomtry with interfaces with CCM+
Nesrine Bouhrira
Rep Power: 11 |
hi,
my geometry includes a tube with a fluid circulating inside it and a braid of solid around it. So I have solid-solid conduction and solid-fluid conduction. I set up the mesh and the interfaces between the fluid-solid region and solid-solid region with CCM+ but the mesh didn't generate. Does it have a problem with the interfaces ? Is it ok to set up two different meshes ? Thank you. NesrineB |
November 24, 2015, 20:24 |
Rep Power: 25 |
Theoretically what your saying is perfectly fine. Can you give more details? i.e. what is the error, what does the geometry look like, how are you meshing it, how did you imprint it, etc.
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 11:49 |
Dynamic Meshing - Interfaces do not stay together | Noblek330 | FLUENT | 1 | September 18, 2014 13:32 |
Singularity of grid?Volume meshing vs face meshing | Ken | Main CFD Forum | 0 | September 4, 2003 12:09 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 12:08 |
