Interpolating Data onto a Uniform Mesh
Like Tree1Likes
  • 1 Post By fluid23
Old   October 30, 2015, 14:14
Default Interpolating Data onto a Uniform Mesh
Wade
wadeellis is on a distinguished road
Hello All,
I am wondering what the best way to export Star-CCM+ data on a uniform grid is. The mesh I generate is not uniform, but I would like to use Star-CCM+ to interpolate the data onto a uniform sized grid of my choosing. Would I use a data mapper? If so, which type is best for a 2D simulation? I understand that data mappers can be used to interpolate data you load into Star onto your mesh, but I want to do it the other way around: I want to interpolate the data generated by the Star model to a mesh I define.
Also, does anyone have any good recommendations for books about Star-CCM+ to learn more about how it works?
Thank you.
wadeellis is offline   Reply With Quote
Old   November 2, 2015, 14:51
Matt
fluid23 is on a distinguished road
there may be another way to do it, but you could use a presentation grid to get evenly spaced planar results.
if the points aren't co-planar then you may have to setup a macro to create the points one at a time.
as far as learning star-ccm you should work the tutorials that come in the installation. look at the help documentation under tutorials...
wadeellis likes this.
fluid23 is offline   Reply With Quote
Old   November 2, 2015, 17:19
Paul Hancock
Paulh is on a distinguished road
The data mappers can be used to export CCM+ results out to either surface or volume mesh.
Paulh is offline   Reply With Quote
Old   November 2, 2015, 17:58
Wade
Thank you MBdonCFD, I was not familiar with the presentation grids or other probes. One of those should do the trick for me.
data interpolation
simpleFoam Floating point error (Core Dumped) sam.ho OpenFOAM Running, Solving & CFD 2 December 31, 2013 07:57
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 11:52
[swak4Foam] Air Conditioned room groovyBC Sebaj OpenFOAM Community Contributions 7 October 31, 2012 15:16
singularity? mihaipruna OpenFOAM Running, Solving & CFD 5 April 24, 2012 18:18
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 18:51
