Visualize overset mesh movement
Like Tree2Likes
  • 1 Post By me3840
  • 1 Post By Alberto Damas
Old   September 29, 2015, 07:48
Default Visualize overset mesh movement
Alberto
Alberto Damas is on a distinguished road
Hello, I am trying to simulate a wind turbine using overset mesh and DFBI mode. I want to visualize and record the movement of the turbine during the simulation. ¿How can I do that?
Alberto Damas is offline   Reply With Quote
Old   October 5, 2015, 21:26
me3840 is on a distinguished road
Create a scene of the thing you would like to see. In the scene properties go to attributes>update and check the save to file option. Configure there how often you would like it to save, and run the simulation.
me3840 is offline   Reply With Quote
Old   October 5, 2015, 21:30
Also, if this is a wind turbine, why do you need overset for that? You can just use RBM.
Old   October 6, 2015, 04:14
Alberto
Because I want the wind velocity as an input.
Is there any way to calculate the inertia values for DFBI?
Thx.
Old   October 6, 2015, 20:22
Using the freestream velocity as an input and the turbine speed as an output does not require the use of an overset mesh. You can use RBM. RBM will be faster and produce less error than overset. You only need overset for large displacements with complex interactions. A wind turbine just rotates, it's simple.
To find the moment of inertia you need to know the mass distribution of the object, I don't think STAR-CCM+ can calculate it.
Nabuchadresar likes this.
Old   October 8, 2015, 05:55
Alberto
You are right, I thought RBM had the rpm as an input. Thx a lot.
I have simulated the same geometry changing some parameters: wind velocity, inicial inertia values (I don't know what this means) and DFBI object mass. None of them change the rpm obtained. Do you know what I am doing wrong?
Old   October 8, 2015, 16:44
Make sure the region that rotates has its motion set to 'DFBI rotation and translation' and only enable rotating in 1 direction.
If you don't know what the inertia values are, you need to take a step back and read about some basic rotational kinematics, you shouldn't be doing this problem yet.
https://en.wikipedia.org/wiki/Moment_of_inertia
Old   March 19, 2016, 14:20
André Luiz Moura Silva Moreira
Nabuchadresar is on a distinguished road
You found the problem?
Nabuchadresar is offline   Reply With Quote
Old   March 21, 2016, 08:31
Alberto
Yes, I don't remember what I did wrong but it works now.
dfbi, movement, overset, visualize
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Overset Mesh Cell Count Kishen STAR-CCM+ 0 April 18, 2014 05:23
Wedge water impact DFBI Overset mesh jcamilleri STAR-CCM+ 1 March 31, 2014 13:58
[ICEM] Mesh Decoupled Mesh Movement in ICEM Julian K. ANSYS Meshing & Geometry 0 October 26, 2011 17:06
