September 11, 2015, 22:59 |
Meshing Process
Sidharth
Rep Power: 11 |
Dear Experts,
I am new to CFD domain, so needed some help regarding the meshing process. Right now I am working on a project of underhood thermal management using Star CCM as solver. Now I want some guidance that how meshing process works when we are dealing with meshing of different parts with the control volume. In the solver there are three different places where the meshing parameters are mentioned, they are 1) The Mesh Continua 2) In the "Regions" node 3) In the individual "boundaries" of the "Regions" node. It is easy for me to understand that how the meshing at the part level is done, but how these different parts are connected in a control volume to form a Single volume mesh, by defining mesh at different level, is difficult to grab. So it will be really great help, if someone can can guide me along the process of meshing i.e how the entire mesh is generated from the part level till the control volume and how they are connected, by defining the mesh parameters at different levels. Thanking You, Sidharth. |
September 13, 2015, 20:08 |
Rep Power: 24 |
1. Your question implies you are using region-based meshing, which is obsolete. I highly recommend you switch to the part-based meshers. Consult the user guide.
2. I can't say I understand your question though. You have global settings for the meshers which apply certain parameters to all surfaces and certain parameters to the core volume, and you can apply custom settings to either of these. The code figures out the sizing based on your parameters and determines how to transition from one to another. |
September 15, 2015, 00:43 |
region based meshing
Bharat
Rep Power: 15 |
Hi sid,
################## region- R part based meshing- PBM region based meshing- RBM #################### I hope you are aware of meshing process in PBM, so without dragging into ocean i'll just stick to your pool of questions. 1) THE MESH CONTINUA here in RBM it is somewhat different compared to PBM. here we define each mesh continua for each region. say you have 3 R's R1, R2 and R3. then you need to define 1 mesh continua for each region. 2) IN THE REGIONS NODE lets keep it default for the time being, since, it have different parameters to be defined for different mesh models you select under models in mesh continua. 3)IN BOUNDARIES as we have surface control in PBM here in RBM we define custom sizes under this node. say you have some small parts whisch has to have small mesh size, just select custom surface size under mesh conditions and define the surface size in mesh values. on a whole PBM is much easier comapre to RBM. yet, the choice is your's. Cheers, bharat
chapter 3: -crossing the threshold- |
September 15, 2015, 02:30 |
Sidharth
Rep Power: 11 |
Hi bharat,
Thank you for the guidance. . I just had one more question that if I need to define a solid mesh in my CFD simulation then, do I need do to it in the PBM, or in the RBM I need to define a solid region and define the mesh continua accordingly..? |
September 15, 2015, 03:31 |
#5 | |
Bharat
Rep Power: 15 |
bharat
[ICEM] Flow channel meshing problems | StefanG | ANSYS Meshing & Geometry | 19 | May 15, 2012 06:44 |
Meshing 3D AHU room | khimkhim | ANSYS Meshing & Geometry | 3 | November 4, 2009 11:26 |
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 11:03 |
Singularity of grid?Volume meshing vs face meshing | Ken | Main CFD Forum | 0 | September 4, 2003 11:09 |
