what is the best method to learn analysis using star ccm? |
March 1, 2015, 03:11 |
Vignesh
Rep Power: 12 |
Hi Im new to cfd analysis..I dont have any prior experience in cfd analysis..can you help me with pdfs n links n say me the best method to learn analysis using star ccm?
March 1, 2015, 03:25 |
Gajendra Gulgulia
Rep Power: 13 |
if you have access to STAR CCM+ pacage, you can press F1 while the cursor is on main window, which will lead you to the hep and tutorials manual, which evidently the best to learn STAR CCM+ software.
I strongly suggest you to learn the surface cleanup and surface repair tutorials very carefully and if need be, at least twice. |
March 1, 2015, 06:06 |
Vignesh
Rep Power: 12 |
Thanks a lot ggulgulia for ur reply☺ .. Is it compulsory to learn surface cleanup and repair in star ccm before going to the next step ? Im asking u this coz Im familiar with HM and Ansa..
March 3, 2015, 14:16 |
Gajendra Gulgulia
Rep Power: 13 |
in that case you can start with the tutorials that you need.
If you have access to steve portal, from there you can get a lot of help on test cases and tips and tricks to set up your simulation quickly I had practiced the tutorials several times until I got developed the intuition to use it smoothly |
STAR CCM & WIN 8 pro | hyderkhan74 | STAR-CCM+ | 3 | March 5, 2014 05:56 |
Star CCM 8.02 compatible version of Netbeans | trsakthipriya | STAR-CCM+ | 2 | July 10, 2013 06:14 |
problem when imported geometry from 3D CAD to star ccm, | TAREK GANAT | STAR-CCM+ | 1 | May 21, 2013 23:15 |
Fluent Vs Star CCM | firda | Main CFD Forum | 3 | February 26, 2011 03:51 |
Equivalent of Gambit neutral file in star ccm | pradeap | STAR-CCM+ | 3 | July 2, 2010 08:36 |
