Problem with convergence of continuity
Like Tree1Likes
  • 1 Post By Clémence
Old   August 12, 2014, 04:03
Default Problem with convergence of continuity
Clémence is on a distinguished road
Why do you think continuity doesn't converge on my simulation? And how could I make it converge without changing the mesh?
For information: I have a geometry of 14 m and aroud 1 million cells. Cells has a base size of 5 cm, which I know is high. I am running in implicit unsteady with time step of 0.01s and a CFL between 1 and 10.
Thank you!
Clémence is offline   Reply With Quote
Old   August 19, 2014, 11:37
Marc Ricart Rius
Mricart is on a distinguished road
Have you checked if the force converge / stabilize? I have read in some places that the residuals in Star-CCM+ are not that important. Besides, all the other goes down quiet a lot.
Mricart is offline   Reply With Quote
Old   August 19, 2014, 11:38
Marc Ricart Rius
You can always check what happens if you change the turbulence models
Old   August 20, 2014, 11:55
Thank you for your answer Mricart.
Actually I already found why continuity was not converging. I was using coupled solver but it was not adapted to my case. With the segregated olver, the convergence is much better.
But there is still some convergence issue. For exemple, in the middle of the time step, residuals make a pic and there is this error message:
Bi-conjugate gradient stabilized solver did not converge !
rgd likes this.
Convergence Centurion2011 FLUENT 48 June 15, 2022 00:29
[ICEM] issue occur after extrude 2D airfoil mesh and convergence problem in CFX shiyun ANSYS Meshing & Geometry 4 May 9, 2012 20:55
Force can not converge colopolo CFX 13 October 4, 2011 23:03
CM+5 Convergence of the nonstationary problem ILYA87 STAR-CCM+ 0 May 22, 2011 05:35
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
