Split a plane surface
Like Tree1Likes
  • 1 Post By me3840
Old   May 15, 2014, 13:00
Default Split a plane surface
Seba
Seba22 is on a distinguished road
Just one stupid question: how can I split a Block face (a plane surface) into more than one boundary?
I need a rectangular face with a circle inscribed into it... and two different boundaries (one for the circle and one for the residual area)...
I'm sorry for the stupid question but i can't find how to do it.
TY
Sebastiano
Seba22 is offline   Reply With Quote
Old   May 15, 2014, 22:04
me3840 is on a distinguished road
If you generated the geometry in 3D-CAD, you can easily imprint a cylinder or a sketch with a circle on to the block.
If you're just using the block in the parts tree, you can generate a cylinder as well, open them both in Surface Repair, and intersect the two.
Seba22 likes this.
me3840 is offline   Reply With Quote
Old   May 16, 2014, 05:45
Seba
I'm using the block in the parts tree and now I'm feeling very stupid:
I did as you said. I selected the block faces first (Face set 1), then the cylinder ones (Face set 2) and clicked "Intersect"... Now the edges of the intersection are selected...and now? I 'm not able to create a new surface with them or a part curve. Failing on easy issue like that is so frustrating -.-
Thank you me3840
Old   May 16, 2014, 06:09
Ping
ping is on a distinguished road
please follow me3840 first suggestion and do this job in 3d-cad since you will need to learn far less
and if you have not used 3d-cad before then do the help tutorial on it designing a cyclone separator
ping is offline   Reply With Quote
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
Free - Surface Flow: Split Fluid Forces acting on a Boat Hull eee CFX 2 August 28, 2009 09:36
Bug: Surface Integral->Sum w/cut plane and x-face-area agodfrey FLUENT 0 June 9, 2009 14:11
postprocessing - surface - plane Brujo FLUENT 2 March 1, 2008 11:36
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
