May 15, 2014, 06:13 |
Simple and Double Precision in STAR-CCM+
jerome stempert
Hi, I'm a French student and i have to use STAR-CCM+ to predict the aerodynamic noise produced by the nose landing gear of the Gulfstream G550.
Currently,, i'm using a simple precision of STAR-CCM+. I wonder what are the difference between simple and double precision and what are the consequences on the predictions of the noise, the pressure and the velocity magnitude ? Is the time simulated will be the same for the same results ? Same question for the time-step requiered ? Thank you. Jerome |
May 15, 2014, 15:50 |
SINGLE and double precision
Dear Jerome,
I think that you mean SINGLE rather than SIMPLE precision. Single precision floating point format is a computer number format that stores information in 4bytes (32 bits) in contrast to double precision that uses 8 bytes (64 bits). There are significant differences concerning the precision of the teo formats. As single precision uses only 32bits (1bit for the sign, 8 bits for the exponent and 24 (only 23 explicitly stored) for the significand precision), the decimal digit precision obly ranges from 6-9 digits, whereas in double precision the 64 bits (1 sign, 11 exponent, 53 (52) significand precision) yield 15-17 precise digits. As you are using single precision, you can only trust 6-9 of all digits and should consider this for your results... Hope that helped, Cheers |
May 15, 2014, 20:50 |
Rep Power: 24 |
While phys-zephyr is correct on what single and double precision means from a mathematical standpoint, it's important to note that STAR-CCM+ does not have a single-precision version.
STAR-CCM+ comes in a mixed-precision and a double-precision version. In the latter, all variables and functions are computed with 64-bit floating point numbers. In the former, all variables and functions except for position/distance (x,y,z) and pressure are computed with 32-bit floating point numbers. The four functions mentioned are computed in 64-bit, regardless of your precision choice. If you are doing a direct noise simulation (not using a broadband model), you should use the double-precision version. The double-precision version will be more computationally expensive, yes. Your timestep is set based upon your physics and your highest desired frequency; the precision of the build has no bearing on this value. |
May 16, 2014, 09:59 |
jerome stempert
Thank you for your both answers.
In fact i'm using a DES model coupled with FW-H method. Have a good day |
simple double precision |
Continuity divergence in simple gas flow | Okka | FLUENT | 7 | January 11, 2019 01:01 |
Scalar precision: float vs. double | Hisham | OpenFOAM Programming & Development | 5 | August 25, 2011 11:24 |
double precision | hsn | CFX | 6 | June 13, 2011 23:18 |
UDF & Double precision; Please help?? | Asghari | FLUENT | 0 | January 31, 2007 13:14 |
