Translate Region to Parts
Like Tree2Likes
  • 1 Post By ping
  • 1 Post By ping
Old   May 12, 2014, 05:55
Default Translate Region to Parts
skapetan is on a distinguished road
Hey guys,
I got a geometry in STEP-format and I imported it directly as a region in Starccm +. Then is splitted the geometry by patch to define several boundaries. After working and repairing the geometry I recognized that it is necessary to select the geometry from the Geometry tree to work with the Volumetric Controls.
So is it possible to translate my geometry from the Region tree (incl. Boundaries) to the Geometry tree and to maintain my defined boundaries so I can get them as parts? Or do I have to start a new simulation?
Thx
skapetan is offline   Reply With Quote
Old   May 12, 2014, 08:17
Ping
ping is on a distinguished road
you can export the imported representation as a dbs file then import this file as a part
then delete the import representation and connect the part to the existing region
it is better to import the cad as iges since it retains the underlying geometry whereas the above technique gives you tesselated surfaces
if you use region based meshing you can use volumetric controls with you existing file but parts based meshing has lots of advantages
skapetan likes this.
ping is offline   Reply With Quote
Old   May 12, 2014, 10:06
Thank you for your response.
I imported the .dbs file and connected the part with following steps to my existing region.
Parts < XY < Set region < XY
Hiow can I check if the connection to my region was succesful?
Thank you
Old   May 12, 2014, 10:30
Ping
clear your generated mesh and remesh - if something is missing you will get an error
but if every part surface is connected to a region boundary which you should first check then it should be fine
Old   May 14, 2014, 05:46
Thank you everything fine
conjugate heat transfer in OpenFOAM skuznet OpenFOAM Running, Solving & CFD 99 March 16, 2017 06:07
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 05:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
