Timestep Size Variable by User Field Function |
December 31, 2013, 04:47 |
Hi all,
I am a beginner in STAR CCM+. I am wondering what is variable of timestep size in user field function of STAR CCM+? In conditional expression, is it possible to define as below structures? if Time > T1 then if position > p1 then...else if Time < T2 then... if position > p1 then...else... I really appreciate your help. |
January 3, 2014, 08:25 |
siamak rahimi ardkapan
Rep Power: 18 |
Your question is not clear. Do you want to know the meaning of time step?
Good luck Siamak |
January 3, 2014, 09:33 |
In user field function, how can I define time step size variable as velocity variable ($$Velocity) or Temperature variable ($Temperature)? Best regards |
January 5, 2014, 01:32 |
KHB
Rep Power: 16 |
Hi, the variable is $TimeStep (If I understand your question correctly)
January 5, 2014, 22:00 |
#5 | |
Thank you for taking your time. I am wondering that the term of $Timestep is the number of timestep or timestep size? For user field function, is it possible to define above structure? Best regards |
January 6, 2014, 02:16 |
KHB
Rep Power: 16 |
Hi ThanhToan,
$TimeStep is the timestep size. Yes, it is possible to define the above structure, if else is normally defined as (if condition) ? (if it is true then do this) : (if it false then do this) For more detail I suggest you have a look on the manual. |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
User field function for specific heat deifnition | crevoise | STAR-CCM+ | 2 | January 28, 2013 04:25 |
User Field Function - interpolatePositionTable | fshak92 | STAR-CCM+ | 3 | May 16, 2012 11:24 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
emag beta feature: charge density | charlotte | CFX | 4 | March 22, 2011 09:14 |
