Tips for air entrainment/bubbles? + steady state multiphase models
Like Tree1Likes
  • 1 Post By Apocolapse
Old   February 17, 2013, 09:07
Post Tips for air entrainment/bubbles? + steady state multiphase models
Apocolapse is on a distinguished road
Can anyone give me some tips on simulating bubbles in a model? Specifically the bubbles are generated by air entrainment.
The model I am looking at is a spillway where the water flow should generate bubbles at the bottom of the tunnel.
I was previously using a VOF model with two Eulerian phases, H20 and Air and in 2D simulations I have a mesh of around 1mm and a timestep of 0.1ms. However the result seems a little off when looking at the volume fraction scalar results.
Also, is it possible to run a VOF model in steady state? I attempted to do this, but the results were extremely erratic. Are there any ways to get an accurate multiphase model using a steady state? There is no temperature change in my model if that helps.
A picture of my model (running at the moment) has been attached to show the sort of simulation I am looking at:
I am relatively new to multiphase models, all my knowledge of which has been self taught, so any advice would be appreciated on the finer options of the models.
Thanks
ali abdulhussein likes this.
Apocolapse is offline   Reply With Quote
air entrainment, bubble, multiphase, vof
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
regarding steady state discrete phase calculations hajszan_gyula FLUENT 1 February 28, 2006 02:32
About the difference between steady and unsteady problems Lisa Main CFD Forum 11 July 5, 2000 15:37
Steady state formulation of turbulence ?? Jitendra Main CFD Forum 1 June 27, 2000 19:49
