How to plot velocity Vs time graph at a point in a flow using starccm+ |
November 9, 2012, 02:58 |
Taryk
Rep Power: 14 |
I m trying to plot a graph of velocity magnitude vs time at a point in a turbulent flow over a flat plate using point probe but i m unable to get a graph. Can anyone help me in sorting out this problem.
Thanks TQIM |
November 9, 2012, 16:43 |
Sergei
Rep Power: 22 |
Create an expression report.
Set your point derived part as an input part for it. Define a report expression as sqrt($$Velocity[0]^2+$$Velocity[1]^2+$$Velocity[2]^2). Create a monitor and a plot from your report. Go to the monitor properties and switch the trigger from 'every iteration' to 'every time step'. |
November 12, 2012, 09:19 |
#3 | |
Ryne Whitehill
Rep Power: 19 |
You could probably just use a sum report and only include that point. Also, I think $$Velocity.mag() would be easier than doing the full equation. |
November 15, 2012, 20:26 |
Rep Power: 22 |
Again, rwryne is right. There is a field function syntax to get the velocity magnitude, but isn't it mag($$Velocity)? At least that's what the user guide tells on page 4784.
Anyway, on an expression report, you can't choose any input parts, so it needs to be a sum, minimum or maximum report. All other reports don't make much sense.
We do three types of jobs here: GOOD, FAST AND CHEAP You may choose any two! |
November 19, 2012, 02:18 |
Taryk
Rep Power: 14 |
Thanks for your reply...I tried with the expression given by you but its giving syntax error. Could you please tell me how to rectify this error.
November 19, 2012, 02:20 |
Taryk
Rep Power: 14 |
Thanks Ryne for your reply but I m getting syntax error when I used the expression given by you. Could you please tell me how to rectify this error.
November 19, 2012, 11:51 |
#7 | |
Reza
Rep Power: 17 |
Can you post the error message? I think the following post gives the correct syntax
problem in toposet | Ahmed Khattab | OpenFOAM Pre-Processing | 27 | March 3, 2023 22:12 |
Multiple floating objects | CKH | OpenFOAM Running, Solving & CFD | 14 | February 20, 2019 10:08 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 16:33 |
block-structured mesh for t-junction | Robert@cfd | ANSYS Meshing & Geometry | 20 | November 11, 2011 05:59 |
Plot a graph of velocity & boundary condition problem | wanie | Fluent UDF and Scheme Programming | 0 | December 11, 2009 11:40 |
