User Field Function - interpolatePositionTable
Like Tree1Likes
  • 1 Post By rwryne
Old   May 14, 2012, 08:00
Default User Field Function - interpolatePositionTable
fshak92 is on a distinguished road
I have a table(x,y,z) with the 4th column of temperature and i want to assign it to my body's wall.
The number of the table'e coordinates is less than my cell's coordinates and a little bit different.
Therefore i defined a user field function to interpolate it.
I used the below code but unfortunately no interpolation can be seen in the temperature distribution(the cells which has not been addressed in table,get a default(300'K) and different temperature of its nearest cells)
interpolatePositionTable(@Table("xx"), "Temperature")
I appreciate any idea.
Thank you in advance.
fshak92 is offline   Reply With Quote
Old   May 14, 2012, 11:20
Ryne Whitehill
rwryne is on a distinguished road
You say the coordinates are "a little bit different". What do you mean by this? Your nodes do not necessarily have ot match up, but the surfaces do need to be coincident
Using a table should do the interpolation for you, so there is no need to go through a field function step.
rwryne is offline   Reply With Quote
Old   May 16, 2012, 07:59
Thank you for the reply.
I have a table of a X machine with a coarser mesh and i want to import it to the X machine with a finer mesh. Due to generating the coarser mesh,there is a little difference between the position of cells in two cases.also there is difference in the number of coordinates.
For simplicity im trying to test it in a sample case.
you can see in the attachment the imported temperature on the finer mesh ,many of blue cells(defualt temperature-300) has not been addressed in the table and it has been set by the software to 300 automatically! neither using table,nor user field function(as i said above) do any interpolation between the cells.
e.g assume we have 3 cells in a line,,the right one is 600"K and the left one is 400. i expect the middle cell would be interpolated to 500. but as you can see in the picture the software use the default value(300) for any unaddressed cells without any interpolation.
Old   May 16, 2012, 12:24
Ryne Whitehill
Hmm. I have always had it interpolate without issues, though I always have planar surfaces (i.e. an inlet/exhaust plane), not complex geometry like yours.
Perhaps try using data mappers? You can export your solution from the coarse file, and import it as a CAE model into the finer mesh.
fshak92 likes this.
Field function lcg44 STAR-CCM+ 1 November 30, 2011 00:13
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 13:21
mean, variance and covariance statistics of any field function on any part. Subhadeep STAR-CCM+ 8 February 18, 2010 18:19
User Field Function hannow STAR-CCM+ 3 November 24, 2009 21:20
