New Dedicated Post-Processing Forums |
View Poll Results: What do you think about this kind of smaller dedicated forums? | |||
Not good at all, keep the discussions on the main forum. | 1 | 3.70% | |
Not sure if it is good, I am a bit hesitant. | 4 | 14.81% | |
It is good to separate the discussions into smaller forums. | 10 | 37.04% | |
Very good, I would like to see more specialized forums. | 12 | 44.44% | |
Voters: 27. You may not vote on this poll |
May 26, 2012, 18:09 |
Administrator
Peter Jones
Rep Power: 10 |
CFD Online has opened dedicated forums for the following visualization and post-processing tools:
This is a test to see how it works out to create smaller dedicated forums. Our policy before has been to try to avoid splitting up the discussions too much with separate forums. However, we keep getting suggestions to do this and with our current forum software it is easy to later change our mind and merge back the forums to the main forum if the test does not work out. If the test works out and we do see an increased number of posts about the visualization tools that have a dedicated forum we might change our mind and be more positive to open other dedicated forums about things like mesh generation softwares, special application areas like turbomachinery, aerospace, automotive, ... special subject areas like turbulence, combustion, numerics, ... We will include a poll with this announcement to give you a chance to tell us what you think about this. |
May 26, 2012, 21:15 |
Suggestion
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Peter,
A little suggestion: a sticky thread or a link or a sticky link (?) would be useful in the new ParaView forum pointing to OpenFOAM's own ParaView+paraFoam one, since there are particular questions related to OpenFOAM+ParaView Best regards, Bruno
May 27, 2012, 07:19 |
Administrator
Peter Jones
Rep Power: 10 |
Good suggestion. I have added sticky posts to both forums to make users aware of the other forum.
May 28, 2012, 03:16 |
cfdkid
Rep Power: 17 |
Hi Peter,
The forum name is cfd-online.com and don't you think bringing post-processing separately might dilute the idea of discussing cfd stuff? Also, people discuss post-processing anyway in each s/w forum. It is only a suggestion tough.
________________________________________ Regards, CFDkid It never gets easier You just get Better |
May 28, 2012, 03:54 |
Administrator
Peter Jones
Rep Power: 10 |
Post-processing can and should of course be discussed in all s/w forum. I agree with your hesitation that discussions might get too spread out. But you could also view this as the opposite. Discussions about these post-processors now have their own forums and do not have to be spread out over all other forums. Besides, we keep getting suggestions to try more specialized forums and instead of saying no again we decided to give it a go now and test it.
May 28, 2012, 03:58 |
cfdkid
Rep Power: 17 |
Yes Sir,
Fair enough.
May 29, 2012, 03:00 |
Reg- forms
GaneshRam
Hi Team,.
It will great if bring some forums on pre and post processing apps and sharing the technical info. Regads Ram |
June 24, 2012, 15:45 |
Alexey
Rep Power: 17 |
It would be quite good to create dedicated Grid-Generation forum also.
June 28, 2012, 07:33 |
Dedicated Grid Generation Forums
#9 |
Administrator
Peter Jones
Rep Power: 10 |
What grid generation forums would you recommend us to open?
We decided to test dedicated post-processing/visualization forums first since it was easier to define which forums to open. With grid-generation the picture is less clear. You have a few dedicated codes that are obvious, like Pointwise, Gridpro, Ansa, Gridgen, ... Then you have a bunch of free codes like Gmsh, Netgen, enGrid and snappyHexMesh. Most of these free codes are not that frequently used and some are closely tied to OpenFOAM and already have dedicated forums in the OpenFOAM section. The CFD code vendors also have many grid-generation codes that to a varying degree are tied to their solvers. I'm thinking of codes like ICEM-CFD from Ansys and es-tools from CD adapco. The Ansys codes already have a dedicated Ansys meshing forum. Then there are a bunch of other codes that to some degree are mesh generators, like for example Sculptor. We are not sure which dedicated grid generation forums to open. Please feel free to give us a list of the forums you would recommend us to open. |
July 5, 2012, 05:32 |
#10 |
Oliver Gloth
Rep Power: 17 |
we are maintaining our own forum for enGrid (see http://engits.eu/vanilla/) and I would be more than happy if we could migrate that to CFD online. Dealing with spam and abuse can be very annoying and CFD Online does a good job of that! The forum is used regularly, although, obviously, not as frequently as some of the other forums here ;-) OpenFOAM is the main target application for enGrid, but it is not restricted to that. So, personally, I would like to see it in a general meshing section. Cheers, Oliver |
July 5, 2012, 06:26 |
#11 |
Administrator
Peter Jones
Rep Power: 10 |
Oliver, thanks for your suggestion. I would be very happy to include an enGrid forum also if we open a dedicated mesh generators section. I will add enGrid to my list of potential Mesh Generator sub-forums.
Last edited by pete; July 5, 2012 at 06:32. Reason: Removed question about placement since it had already been answered. |
July 14, 2012, 12:59 |
#12 |
Bruno Santos
Rep Power: 128 |
Hi Peter,
In case NETGEN (including nglib) isn't on your list for meshers yet, seems some people tend to look about it here at CFD-Online, as in this case: http://www.cfd-online.com/Forums/ope...tml#post371025 Although NETGEN already has an active mailing list: http://sourceforge.net/projects/netgen-mesher/forums ... Best regards, Bruno
avizo, ensight, fieldview, forum, paraview, post-processing, tecplot, vizualization |
LinkBacks (?)
LinkBack to this Thread: https://www.cfd-online.com/Forums/site-news-announcements/102518-new-dedicated-post-processing-forums.html
Posted By | For | Type | Date | |
This Week in CFD | Another Fine Mesh | This thread | Refback | June 5, 2012 09:37 | |
This Week in CFD | Another Fine Mesh | This thread | Pingback | June 1, 2012 11:05 | |
Twitter / albertop78: RT @cfdonline: Opened dedi | This thread | Refback | May 27, 2012 21:55 |
Guide: Getting Started with the CFD Online Discussion Forums | pete | Site Help, Feedback & Discussions | 8 | July 29, 2016 06:00 |
Ansys Post processing | ano999 | ANSYS | 1 | May 27, 2011 17:24 |
NO model vs post processing in coal combustion,CFX | sakalido | CFX | 1 | April 15, 2011 15:07 |
post processing for KIVA | dirga | Main CFD Forum | 5 | April 23, 2009 11:58 |
Post Processing in FEM | Abhijit Tilak | Main CFD Forum | 0 | April 26, 2004 12:59 |
