August 24, 2018, 16:32 |
Weird double-line-break is happening...
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
This has been happening at least with Firefox on Ubuntu and it has not been happening to just me, since I'm seeing this happen in other posts, as well as PMs sent to me.
Take for example the line space I've added above, to separate my two paragraphs. I only left a single empty line, but after posting, it was rendered as 2 empty lines. Same happens if in advanced mode, I switch the Editor Mode with the button on the top right of the editor box. If I use Shift+Enter, then it is rendered only as a single empty line, as shown in the empty line just above this paragraph. I have yet to test this with other browsers, so I don't know if it was due to a recent change in the forum software or on Firefox. |
August 27, 2018, 09:12 |
Problem with recent Firefox versions, solution found
Administrator
This is caused by a change in recent Firefox versions (see http://forums.mozillazine.org/viewto...?f=9&t=3040337 for more discussions).
Both Chrome and Internet Explorer work correctly for me. You can get Firefox to work correctly also by going to "about:config" in Firefox and toggle "editor.use_div_for_default_newlines" to be "False". I will wait with looking at possible changes in the forum software setup since this only seems to affect Firefox and I hope that Firefox will fix this soon. It is a Firefox bug that affects the forum behaviour. |
August 30, 2018, 13:12 |
Administrator
Bug has been reported to bugzilla and confirmed by them on this forum, so now it is reported correctly to the people behind Firefox. You can follow the bug report here:
https://bugzilla.mozilla.org/show_bug.cgi?id=1486513 |
Derivative of velocity and mean velocity | hiuluom | OpenFOAM Post-Processing | 1 | May 30, 2015 00:42 |
1.7.x Environment Variables on Linux 10.04 | rasma | OpenFOAM Installation | 9 | July 30, 2010 05:43 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 13:24 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 15, 2003 00:19 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 16:16 |
