March 16, 2012, 04:02 |
Adding Temperature in channelFoam
supercommandodhruv
Rep Power: 15 |
Hi Foamers,
i am doing a simulation on channel flow using LES modelling. I want to impose a temperature on the walls of the channel and study the effects of conduction+convection on the fluid flowing through it. Can anyone give me some ideas on how to implement this? I can't impose a cyclic BC on temp, since it is not cyclic. Is there any other solver that I can use that gives me the local temperatures in the fluid field? My main intention of using a channel flow for this problem is that the geometry I need to simulate is a very long one, and I am using just a part of it with cyclic BCs. Any help would be very grateful. Regards, Dhruv. |
March 16, 2012, 14:36 |
Kent Wardle
Rep Power: 21 |
Have you looked at this?http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam
March 20, 2012, 17:17 |
David Theriault
Rep Power: 14 |
Hi Drhuv
It depends on the fluid and the Re number of your simulation. If your case can be considerate as incompressible, you could check on how the buoyantBoussinesqPimpleFoam is coded. Because this solver is only for RANS cases, you'll need to modify it. Check the pimpleFoam solver for an idea. David |
April 27, 2012, 06:02 |
anonymous
Rep Power: 14 |
Hi! I do all the tutorial to add the temperature, but it gives me a fatal error: keyword inlet is undefined in dictionari .../0/p::"boundaryField"
I don't understand this problem because I did't change anything about the pressure |
April 28, 2012, 01:50 |
A_R
Rep Power: 17 |
Dear libia
you may define a BC in your mesh boundary but you do not implement it in your /0 folder for pressure. |
April 30, 2012, 03:07 |
anonymous
Rep Power: 14 |
April 30, 2012, 06:11 |
A_R
Rep Power: 17 |
April 30, 2012, 18:12 |
#8 | |
Nima Samkhaniani
Rep Power: 25 |
your modified solver: 1) modified solver: channelFoam + scalarTransportFoam 2) BC: modified fan boundary condition i suggest to look at fluent tutorial guide to find how to formulate cyclic boundary condition |
May 3, 2012, 03:39 |
#9 |
anonymous
Rep Power: 14 |
May 3, 2012, 04:42 |
#10 |
Tibor Nyers
Rep Power: 17 |
I while back when I started my endeavours with OpenFoam I looked at some Fluent tutorial cases and wanted to migrate them to OF. It was too much for me eventually ... so I dropped the idea.
But there was a case with periodic flow and heat transfer - as I investigated the possible solutions I found that the solver is based on "Fully Developed Flow and Heat Transfer in Ducts Having Streamwise-Periodic Variations of Cross-Sectional Area" by Patankar, Liu, and Sparrow. And unfortunately, that concluded my project since I didn't find anything similar in OF - I didn't even know at that time that channelFoam exists and can simulate periodic flow. Good luck and report back if you have some nice results! |
May 5, 2012, 05:40 |
#11 |
A_R
Rep Power: 17 |
Adding temperature equation to porousSimpleFoam | David_010 | OpenFOAM Programming & Development | 9 | February 14, 2018 01:22 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Adding a new temperature dependent viscositymodel? | dgadensg | OpenFOAM Programming & Development | 10 | May 22, 2010 05:47 |
Adding temperature equation in settlingFoam | sachin | OpenFOAM Running, Solving & CFD | 2 | March 31, 2010 03:21 |
Adding temperature field to InterFoam | yapalparvi | OpenFOAM Running, Solving & CFD | 8 | October 14, 2009 20:18 |
